Author Topic: Crank seal replacement?  (Read 1483 times)
« on: 24 June 2007, 21:12:15 »
Looks like I'm going to have to tackle this. I have PMd mark, but here are a few questions:
how do I lock the crank in place, to undo the pulley bolt?
Do I  need to remove / refit the pulley in any order - don't want to mess up the timing!!
Nickbat
Re: Crank seal replacement?
« Reply #1 on: 24 June 2007, 21:21:05 »
« Reply #2 on: 24 June 2007, 21:26:05 »
James is this tool any good?
http://www.justoffbase.co.uk/Crankshaft-Pulley-Removal-Tool-Set-13pc-Sealey-PS997
Nick
Not at £81 - wouldn't use it enough!!
Martin_1962
« Reply #3 on: 24 June 2007, 21:34:07 »
It's a manual so stick it in a high gear and pull the hand brake on hard.
Tippex the crank and pullies as you go.
« Reply #4 on: 24 June 2007, 22:07:30 »
Could also fabricate a metal plate / strip that will bolt onto a couple of the holes where the aux belt pulley attaches, and on to a couple of convenient bolts on the block to lock it in place.
Mate of mine used to swear by the "put a big breaker bar in it, brace it against the ground and turn the engine over on the starter" method  :o :o :o
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #5 on: 24 June 2007, 23:12:11 »
I have done this with 4 cyl cars, please dont forget to disconnect the coilpack!!!!
« Reply #6 on: 24 June 2007, 23:24:25 »
I DID think about getting something on where the aux belt pulley bolts go..
But that engine won't be cranked on the starter until it's all back together ;D
