Author Topic: Oh bo@&%cks  (Read 4349 times)
Oh bo@&%cks
« on: 24 June 2007, 16:34:57 »
Bloody tractor  >:(
Driving back from scrappy, lost drive again, so pulled in a gateway  >:(
Not wanting to go on dual carriageway, I turned it round to come back the little lanes, and it seemed it had lost 4th initially, so locked it in 3rd. When nearly home, I tried to use all gear, and it was fine again, and has been since  :-/
Tunnie and I checked the atf level (slightly high, but this should be normal once the oil has been used?), and the oil that came out had a definate redness to it, although browny.
Any autobox experts care to comment?
Re: Oh bo@&%cks
« Reply #1 on: 24 June 2007, 16:44:51 »
did it go to limp mode?
Re: Oh bo@&%cks
« Reply #2 on: 24 June 2007, 16:57:29 »
nope.
Re: Oh bo@&%cks
« Reply #3 on: 24 June 2007, 17:32:40 »
nope.
Hmm.. would have thought if it was a mechanical failure, it wouldn't start working again.
Shagged AR25? Very much doubt it... but as I found out, they can just let go, at any time :( :(
Re: Oh bo@&%cks
« Reply #4 on: 24 June 2007, 17:33:35 »
Silly thought, but,
You now have a different selector switch since we changed the box.
I just wonder, if it was nudged into N enough not to be in gear?
Re: Oh bo@&%cks
« Reply #5 on: 24 June 2007, 17:38:07 »
Silly thought, but,
The second it happened, I looked down, D selected, and lit up.
Identical symptoms to when it let go last time (only I wasn't ragging it this time), only I can't get it to reoccur now.
sassanach
  • trowbridge
Re: Oh bo@&%cks
« Reply #6 on: 24 June 2007, 20:33:28 »
dare i say it .....check the sump for the thrust washer.
Re: Oh bo@&%cks
« Reply #7 on: 24 June 2007, 20:46:53 »
I sincerely hope not :(
Jaime, if you need help changing the Box again, I will gladly come and assist you mate.
Re: Oh bo@&%cks
« Reply #8 on: 24 June 2007, 20:56:37 »
Thats where my money would be, thrust washer failed.......its a second hand box and nicely underwrites the things we were saying recently about re-building them
You just dont know how good or bad a second hand part is......even if its been seen running or been driven.
Craig_R
  • Watford
Re: Oh bo@&%cks
« Reply #9 on: 24 June 2007, 21:04:10 »
Awwwww bugger After All that Time replacing it I feel for you  :'( One Good Thing Is You know how to replace one now should not take that long second time around if it is totaly knacked
Craig
Mod's
[To be Fitted]Reverse Sensors
Re: Oh bo@&%cks
« Reply #10 on: 24 June 2007, 22:06:02 »
i am wondering if there was too much fluid in the box? We checked the level in my garage, quite a lot came out.
Could an overfill of ATF, have caused it to heat up too much? For the past 5 miles or so it was driven very easy, very unlike Jaime!   ;)  ;D
Now that we drained out the excess ATF, wondering if that cause the problem  :-/
sassanach
  • trowbridge
Re: Oh bo@&%cks
« Reply #11 on: 24 June 2007, 22:11:07 »
do you believe in father christmas?
Re: Oh bo@&%cks
« Reply #12 on: 24 June 2007, 22:11:32 »
It was raining hard, and I have no confidence in the rear tyres ::)
Hence why (due to forecast downpours tomorrow) I was going to use the MV6 tomorrow anyway...
Re: Oh bo@&%cks
« Reply #13 on: 24 June 2007, 22:12:07 »
The oil will increase in volume the more its used...
Re: Oh bo@&%cks
« Reply #14 on: 24 June 2007, 22:12:38 »
Big fat bloke, grey beard, dresses in red?
