Author Topic: Very slight squeek from ? Prop ?  (Read 1631 times)
    • 530D M Sport, 330i Coupe
« on: 21 June 2007, 16:33:44 »
When the car is in P or N and idling there is a very slight squeek, as soon as you increase the revs or engage D or R it disappears....
Doesn't sound load enough to be coming from the prop but does seem to be from round there.....
Any ideas?
hotel21
  • The Kingdom of Fife
Re: Very slight squeek from ? Prop ?
« Reply #1 on: 21 June 2007, 17:38:36 »
If you are in P or N then, unless I have got it wrong, you are stationary and the prop is not turning so need to look elsewhere.....
Aux belt?  Power steering pump?
« Reply #2 on: 22 June 2007, 08:37:25 »
Good point, i'll check again tonight. It seemed that the noise was coming from the rear underside but then finding the source of squeeks and rattles can be very deceptive!
« Reply #3 on: 25 June 2007, 08:47:46 »
Located the squeek, it's the N/S exhaust that seems to be vibrating so I guess there must be a missing mount somewhere.
