Author Topic: breather pipes  (Read 1222 times)
OMEGA VXR
  • Leicester
  • I love my Omega
breather pipes
« on: 26 June 2007, 13:24:54 »
Ive Cleaned all the breather hoses that i could get to but how do you get to the one at the back of the plenum its the one where it looks like its going at the bottom of the engine im refering to the steel one, Ive removed the rubber hose cos mines got a plastic box which is a filter.
Is it a big job?
Any help would be great
Thanks
Lee
[img name=signat_img_resize]http://i159.photobucket.com/albums/t146/WJones_2007/Lee%20Photos/DSCF0113-2.jpg[/IMG]  [img name=signat_img_resize]http://i159.photobucket.com/albums/t146/WJones_2007/Lee%20Photos/DSCF0114-1.jpg[/IMG]
nixoro
  • Hitchin, Herts
Re: breather pipes
« Reply #1 on: 26 June 2007, 13:33:26 »
I have replaced one on my dads 2.0 jack the passenger side up and put it on axle stand for safety, I suggest you do this with the engine cold then climb under unfortunately you need flexible arms for this but you can reach it easier by going either side of the down pipe, I managed to do it by getting to it from the side, its held in place by 2 bolts not 100% sure whether they are held in with allen key bolts or socket bolts.
Another way to do it is to remove the breather pipe is to remove the exhaust manifold heat shield then remove the rail which bolts to the manifold can be fiddly and involves removing the breather which runs on from the rail, I think you can then reach down and undo the 2 bolts
Both ways can be a fiddly job but once the 2 bolts are removed it just comes away
Hope this helps :y
« Last Edit: 26 June 2007, 13:40:23 by nixoro »
