Author Topic: Autobox  (Read 2725 times)
Owen
  • Milton Keynes
Autobox
« on: 26 June 2007, 14:04:47 »
Was out this morning and when coming off the A5 and coming to a stop at athe junction 'Automatic gearbox' appeared on my display.
The car seemed to be stuck in 1 gear! :o  Got home, turned the car off and panicked! ;D
On starting the car up again the autobox seemed to work fine ::)
Any ideas, should I be worried? ;D
Martin_1962
Re: Autobox
« Reply #1 on: 26 June 2007, 15:23:46 »
Do you get funny flashing lights on the selector?
Owen
  • Milton Keynes
Re: Autobox
« Reply #2 on: 26 June 2007, 15:49:45 »
NO mate, select  lights were as they should be
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: Autobox
« Reply #3 on: 26 June 2007, 16:04:13 »
How many miles has the gearbox done?
Martin_1962
Re: Autobox
« Reply #4 on: 26 June 2007, 16:49:33 »
Oil & Filter change?
Re: Autobox
« Reply #5 on: 26 June 2007, 16:51:19 »
For some reason, the box detected a fault, and put it in limp mode (hence the MID msg).
Unfortuantely, it needs a good code reader to read gearbox to find out what it stored.
Whatever, it may be worth planning a fluid and filter change on the box (£60ish if you do it yourself).
Dave-C
  • Staffordshire
  • The Old Girl
Re: Autobox
« Reply #6 on: 26 June 2007, 17:16:43 »
Been through any deep water?  Selector wet!!!
http://www.omegaowners.com/forum/YaBB.pl?num=1182802365/0
« Last Edit: 26 June 2007, 17:48:39 by dave_c »
Owen
  • Milton Keynes
Re: Autobox
« Reply #7 on: 26 June 2007, 18:49:44 »
Just the once which was today!
Taxi_Driver
Re: Autobox
« Reply #8 on: 26 June 2007, 20:01:30 »
Isnt limp mode just 3 and 4 ?
But agree you need to get the g/b ecu read for stored codes  :y
A cheapo tech2 might do it.
Re: Autobox
« Reply #9 on: 26 June 2007, 20:05:05 »
With the standard supplied software, the cheapo doesn't read autoboxes...
Taxi_Driver
Re: Autobox
« Reply #10 on: 26 June 2007, 20:09:46 »
It used to on my 2.2 until vx changed the g/b ecu and updated to ver 10.....now it carnt  :(
Why i said might..... :y
Re: Autobox
« Reply #11 on: 26 June 2007, 20:23:45 »
Ah right, I stand corrected :y
Owen
  • Milton Keynes
Re: Autobox
« Reply #12 on: 26 June 2007, 21:55:41 »
Ok, all of that means absoloutly nowt to me! ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
