Author Topic: Yup, all done!  (Read 6518 times)
Owen
  • Milton Keynes
Yup, all done!
« on: 27 June 2007, 17:51:21 »
Started it all this morning, engine flush, oil change, filter change! :y
And following forum advice carefully, got the plenum off, and cleaned the throttle bodies, breathers and plenum! :y
Put it all back together and it all seemed to work :)
Drove down the road, COOLENT LEVEL came up on the display :-?
Had forgot to put on the water pipes to the plenum :-[ :-[ ;D Water everywhere!
Filled up the water, made sure the pipes were back on, and, what a difference!
Would never have thought that a good cleaning and oil would make such a difference! :) :) ;)
I know it aint a big job for a lot of you guys, but for me it a small victory! If nothign falls off ;)
And I would have been well phucked if it hadnt have been for you lot and advice given, cheers. :y
But still stalling :(
And that long belt at the frount that goes roung the thats the cam belt right? Well a few of the little wheels it loops round are making an orible squeeking sound, like there dry of lube of somthing. Any ideas? :-/
« Last Edit: 27 June 2007, 17:52:33 by Owen »
Danny
  • Wigan, Greater Manchester
Re: Yup, all done!
« Reply #1 on: 27 June 2007, 18:06:37 »
when did it have the full cambelt kit changed?
Owen
  • Milton Keynes
Re: Yup, all done!
« Reply #2 on: 27 June 2007, 18:22:27 »
Dunno to be honest, only had it a few weeks, buy no recipt for cambelt with the paperwork!  Could be 5K ago, could be 55K ago! :-/
« Last Edit: 27 June 2007, 18:23:07 by Owen »
Timbuk
  • Telford
  • owned a Datsun 120y once!
Re: Yup, all done!
« Reply #3 on: 27 June 2007, 18:34:11 »
Thats the Aux belt, cam belt is in the cover behind it ;)
Owen
  • Milton Keynes
Re: Yup, all done!
« Reply #4 on: 27 June 2007, 19:21:57 »
THe stalling thing, just been out and had a look at it on tickover. I ticks just over 500K purs nicely, but the just dies! like the ignition has been turned off!
Any other ideas?
Timbuk
  • Telford
Re: Yup, all done!
« Reply #5 on: 27 June 2007, 19:31:24 »
Any other ideas?
Do a paperclip test , see if it shows up any faults ;) then post them up
See here
http://www.omegaowners.com/forum/YaBB.pl?num=1152601768
Dave-C
  • Staffordshire
  • The Old Girl
Re: Yup, all done!
« Reply #6 on: 27 June 2007, 19:41:18 »
My money is on CPS or ICV,  paperclip test to prove as per Timbuck..
DC
Owen
  • Milton Keynes
Re: Yup, all done!
« Reply #7 on: 27 June 2007, 20:20:43 »
Right then, will do the paper clip test in the morning and let you know the crack! ;)
Re: Yup, all done!
« Reply #8 on: 27 June 2007, 20:39:36 »
waiting for owen to post back a code 19.....
Timbuk
  • Telford
Re: Yup, all done!
« Reply #9 on: 27 June 2007, 20:44:42 »
Thats not my favourite number today >:(
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Yup, all done!
« Reply #10 on: 27 June 2007, 21:18:04 »
So if a code 19 comes up what is the problem then? :-?
Mine was very slightly missing at 500 rpm tick over, if i turned the air con on it would also cut out....
So I reckon mine could have been a mixture of things,
1/ plugs and Leads
2/ the ICV wanted cleaning out
3/ the air con needed filling, which allowed the pump to turn very slowly even when turned off
« Last Edit: 27 June 2007, 21:21:44 by Loo-knee »
Timbuk
  • Telford
Re: Yup, all done!
« Reply #11 on: 27 June 2007, 22:08:09 »
1/ plugs and Leads
your crank sensor is fooked  >:(
x25xe
  • Hayes, Middlesex
  • Avater removed due to size
Re: Yup, all done!
« Reply #12 on: 28 June 2007, 10:03:49 »
In that case, either do it or get it done straight away - make sure that it is the full kit which means belt, tension rollers and rollers.  If your mileage is fairly high say 80K and above, then get the water pump changed as well.  Broken tension roller means broken engine!!
Just stating this in case you do not already know!
Owen
  • Milton Keynes
Re: Yup, all done!
« Reply #13 on: 28 June 2007, 10:13:46 »
Oh Fuk thats not good :o
If it goes I lose my engine :o
Should I drive the car?
And get the water pump changed as well, i know from what i have read on the forum that the cam belt and water pump are expensive jobs, and way beyond me mechanicaly and financialy!
fuk, fuk , fukety fuk!
Just when I thought it was all going well ::)
Timbuk
  • Telford
Re: Yup, all done!
« Reply #14 on: 28 June 2007, 10:14:32 »
Was supposed to be changed at 96,000, car now on 112,000 i believe but no evidence to support this unfortunately :-/
