Author Topic: can somebody please help???  (Read 13863 times)
nij
  • manchester
« on: 27 June 2007, 22:09:59 »
I'v just bought a m-reg 2.0 16v select, manual, when I picked it up 3 days ago it was running fine but then the engine managment light came on and stayed on permanently, the car still started and drove fine for the rest of the day but when I came to it the next morning it just wouldn't fire, I'v checked the fuel is getting through and there is a nice strong spark, I checked all the sensor connectors I could see and sprayed them with wd40, today I tried towing it with my dads tranny van and we done around 3 miles on an open roud trying to bump it and still got nothing but when I turned the ignition off and back on again whilst in second gear it would fire up for around 3-4 revs then die again, I'v spent all day today reading about the paperclip test and tried it with a mate but couldnt make head nor tail of it, which flashes do you count as there seems to be wierd flash inbetween a normal flash, I dunno it totally lost me! just wondered if any one has had the same problem and how they solved it as I'v tried everything to my knolege and it's getting very depressing!! please help!!
Re: can somebody please help???
« Reply #1 on: 27 June 2007, 22:12:55 »
Welcome to the site.
The 2.0l I think gives 4 digit code, so 10,3,4,10 flashes = 0340
Does that make a little more sense?
nij
  • manchester
« Reply #2 on: 27 June 2007, 22:17:21 »
not really mate, It was a pain to count as I was unsure which flashes to count, do you start counting as soon as the ignition comes on and dont count the wierd flicker or count the wierd flicker and not the normal flashes? if you know what I mean
« Reply #3 on: 28 June 2007, 09:40:18 »
It will be main flashes - I have seen a 'double flicker' but only with engine running (can't do paperclip test on 2.0l with engine running though)
Try it with just main flashes. If unsure, try to video it and post it up....
nixoro
  • Hitchin, Herts
« Reply #4 on: 28 June 2007, 11:18:41 »
I think this is year dependent as the earlier omega flash 2 digit codes or atleast my dads does.
« Reply #5 on: 28 June 2007, 11:26:17 »
OK, ta, never flashed a 2.0l, only v6. Nowadays, couldn't be bothered with a paperclip, and plug in a tech2 instead ;)
nij
  • manchester
« Reply #6 on: 28 June 2007, 14:12:13 »
I have a video clip of it but does anybody know how to post ??
nixoro
  • Hitchin, Herts
« Reply #7 on: 28 June 2007, 14:17:34 »
I think you need to upload it to www.Photobucket.com or http://imageshack.us and from there it should give an URL address if you cut and paste into one of your post it should work.
HTH
« Last Edit: 28 June 2007, 14:18:24 by nixoro »
nij
  • manchester
« Reply #8 on: 28 June 2007, 14:33:44 »
nij
  • manchester
« Reply #9 on: 28 June 2007, 14:39:03 »
HTH
nice one mate
« Reply #10 on: 28 June 2007, 14:48:36 »
Yeah, see what you mean, thats not right.
You shorted out pins 4 and 6?  (also, presumably, it doesn't flash without the paperclip, indicating immobiliser fault?)
nixoro
  • Hitchin, Herts
« Reply #11 on: 28 June 2007, 14:55:59 »
Damn that vid goes fast could be wrong
1st part I got was code 53         Fuel pump relay         Voltage low
Looks like it flashes 53 12 12 ...
I think after the 12 12 it flashes  92         Camshaft sensor         Incorrect signal
Just trying to make sense of the rest. can anyone confirm
Codes checked here http://www.topbuzz.co.uk/info/fault_codes/fault_codes.htm#simtec56
« Last Edit: 28 June 2007, 15:04:33 by nixoro »
nij
  • manchester
« Reply #12 on: 28 June 2007, 15:00:38 »
yeh it was defo 4 and 6, I spent most of the day reading about it to make sure, I have just took off the steering wheel casing and come accross an old snapped vauxhall key insulation taped to what looks like some kind of immobilsor that should be on or connected to the black cap at the back of the ignition, is there any way of bypassing the immobilisor to check?
nixoro
  • Hitchin, Herts
« Reply #13 on: 28 June 2007, 15:08:44 »
It could be the last owner never transferred the internal chip to the new key.
nij
  • manchester
« Reply #14 on: 28 June 2007, 15:13:23 »
I'v been onto the last owner who isnt keen in giving me any pointers, the car has full vauxhall service history so I thought trouble free motoring for a while but how wrong was I! only done 23 miles since owning it!
Pages: [1] 2 3 4  All   Go Up
