Author Topic: Estate oil leak - VERY Bad news :(  (Read 1832 times)
« on: 30 June 2007, 13:11:10 »
Mrs Jv6CDX and I spent a long time last night, by means of lights, (!) changing the crankseal and re-fitting the cambelt kit and front end bits. Thankfully she started fine, so I'm feeling pleased I've sucesfully done a crank seal.
The really bad part - is that although it had a tiny tiny leak, it wasn't the crank seal that was leaking at all.
It is the upper-sump to block joint, that's leaking oil, down by the alternator. I cleaned off the oil, and when I rev the engine, I can see oil seeping out of here. At least, I presume it's the seal that's gone.
I've heard VERY nasty stories about changing the upper sump gasket, and I no longer have any access to engine supporting gear. Can anyone tell me the steps involved, in changing this gasket?
Dazzler
  • Haverhill, Suffolk
Re: Estate oil leak - VERY Bad news :(
« Reply #1 on: 30 June 2007, 13:16:56 »
Sorry to hear that James, you seemed to be going so well on it. Good luck for the next stage mate ;)
« Reply #2 on: 30 June 2007, 13:18:34 »
I will fix it. Nothing beats me  [smiley=evil.gif]
I'll admit to feeling a little disheartened though, especially as it's raining...
« Reply #3 on: 30 June 2007, 14:08:23 »
It's like a pin-hole leak - I wonder if it could somehow be patched  ::)
Dazzler
« Reply #4 on: 30 June 2007, 16:48:46 »
I think Winns do a oil stop leak, which basically softens the gaskets a little making them more supple again, hence stopping the leak.
I haven't tried it personally so i don't know how true it is.
Page created in 0.009 seconds with 21 queries.
