Author Topic: Project Tractor  (Read 5067 times)
Project Tractor
« on: 20 June 2007, 23:23:41 »
Or whatever its called.
Now it has a gearbox (thanks to LB66, JV6CDX, Tunnie, and Ronnie), time to get back to its overheating issues.
As I really, really, really do not want to take head off (I think it may be beyond my limited abilities), and further ideas before I have to go down that route?
Craig_R
  • Watford
Re: Project Tractor
« Reply #1 on: 21 June 2007, 10:24:44 »
Have a bash at what we all said on Sunday Try and Run Her With The Grill Off to see if she drops in Temp By a Good Amount
Craig
Mod's
[To be Fitted]Reverse Sensors
Re: Project Tractor
« Reply #2 on: 21 June 2007, 10:42:13 »
Craig
We gave that a try, took the grill off and a run to Halse. It did run cooler apparently, but not by much.
Re: Project Tractor
« Reply #3 on: 21 June 2007, 11:33:03 »
Off with its head....
Martin_1962
Re: Project Tractor
« Reply #4 on: 21 June 2007, 12:23:56 »
Remove the head and pull out the blockage
Re: Project Tractor
« Reply #5 on: 21 June 2007, 19:03:44 »
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Project Tractor
« Reply #6 on: 21 June 2007, 20:34:57 »
Go for it, I'll give you a hand if you can wait a couple of weeks or so.
I like red cars
Re: Project Tractor
« Reply #7 on: 22 June 2007, 07:39:47 »
Likewise...
Before I get cracking on my (hopeful!) project Elite Estate  ::)
(Maria don't read this....) ;D
wombatcurry
Re: Project Tractor
« Reply #8 on: 22 June 2007, 09:50:15 »
The overheating problem - I've not followed this one for some time due to problems at work - but I've recently read on a French site something about bad earthing causing high temperature readings - before tackling the head, are you sure that the problem is real and not sensor-related?
Re: Project Tractor
« Reply #9 on: 22 June 2007, 11:02:53 »
Ow yes, its real......live Tech2 readings (the ecu temp sensor does not use the 0V chassis connection) and the occasional appearanch of 'old Faithful' from the coolant tank cap
wombatcurry
Re: Project Tractor
« Reply #10 on: 22 June 2007, 12:29:38 »
Sounds like you're taking the head off then, I'd be very interested to know what you find in there when you get round to it..... Good luck
Auto Addict
  • North Birmingham
    • Astra K Elite ST
Re: Project Tractor
« Reply #11 on: 22 June 2007, 14:36:22 »
Valves? ;D
I like red cars
Re: Project Tractor
« Reply #12 on: 22 June 2007, 15:27:36 »
You are too kind to it. There is always some activity around the cap. Usually just hissing, but if I have been thrashing the nuts off it, coolant will pop out...
pete1666
  • Bridgwater Somerset
Re: Project Tractor
« Reply #13 on: 22 June 2007, 18:16:26 »
hi i have seen previous thread but  normally in my experience the water pump failing will dump
water after a good thrashing or thermostat failing to open enough.   you probably already
checked this but just a thought!!!
smoothomega
  • Perth, Western Australia
  • 2002 2.2DTI CDX,
Re: Project Tractor
« Reply #14 on: 22 June 2007, 23:44:28 »
Hi Jaime, i know i have posted about this problem before but a thought has just come to me. Many years ago on a totally different car i remember that the expansion bottle had gone brittle and became pourous, it let out the pressure but not the coolant but it did push up the temp. It was only after a total engine replacement was the problem found. Just a thought. Also is the intercooler working as it should? if it has a hole in it and the engine is not getting the amount of air it needs and will make the engine run hotter.
