Author Topic: suspension/steering  (Read 2435 times)
TOOL
  • S Wales
suspension/steering
« on: 30 June 2007, 15:09:20 »
not sure where to begin.......
noticed a slight knock when driving along and the road is pot holed or going over a large speed hump.
can't feel it only hear it.
well after spending nearly 3 hrs under the front of the car checking bush's ect,can't find any thing wrong :-/nothing seems out of the ordinary.
any ideas peeps
ext_0........ Omega 3.0,Xr3i cabby
hotel21
  • The Kingdom of Fife
Re: suspension/steering
« Reply #1 on: 30 June 2007, 15:15:36 »
« Last Edit: 30 June 2007, 15:19:24 by hotel21 »
Weds
  • Chatham, Kent
  • My other hobby
    • Mercedes E class 350 CDi
« Reply #2 on: 30 June 2007, 15:46:16 »
Anti roll bar drop links.
http://www.omegaowners.com/forum/YaBB.pl?num=1182032098/6#6
I'd second that, and you won't be able to detect any play whilst there on the car, and not much difference when there off the car.
TOOL
  • S Wales
« Reply #3 on: 30 June 2007, 16:16:27 »
errrr so  not wanting to appear a thicky then ........how do you know if there ok then?
don't want to replace em if it don't cure the problem :(
Dazzler
  • Haverhill, Suffolk
« Reply #4 on: 30 June 2007, 16:51:30 »
They are only about £15 a pair, and quite simple to replace ;)
Cav9_4
  • Sutton-In-Ashfield,Notts
  • 2003 Omega 2.6 Elite
« Reply #5 on: 30 June 2007, 17:04:01 »
Hi...what i usually do is to jack up and support both sides of the car so both front wheels are off the ground,then check for any play/looseness in the links..HTH...Wayne
TOOL
  • S Wales
« Reply #6 on: 30 June 2007, 20:30:38 »
exactly what I did,no noticable play :-/
I know it's an easy job to replace em,just a great beliver in "if it ain't broke leave it alone LOL" :)
But having read as many links on here as I could find,it does seeem as if replacing may be the answer :)
I'll get some on Monday and give it a go   ;)
old cruiser
  • Slough
« Reply #7 on: 01 July 2007, 14:56:42 »
If these don't cure it then other most likely cause is the wishbone bushes
Cheers Pete
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #8 on: 01 July 2007, 23:14:13 »
Have you tried the top suspension leg mounts for wear. ::)
Jaguar XJ6
Page created in 0.227 seconds with 20 queries.
