Author Topic: Idle control valve  (Read 3096 times)
amba
  • Medway towns
    • German V6
Idle control valve
« on: 01 July 2007, 19:59:43 »
After having  spent a very stressful weekend changing bits that might not have been the problem am now going to do a thorough clean and inspection in morning of tps and wiring/icv and wiring and anything else that causes my mega to run erratic....can anybody give me advise as to best way to clean or service icv as vx want arm and leg for new one and have read before somewhere they can be cleaned and work as new after.
Re: Idle control valve
« Reply #1 on: 01 July 2007, 20:03:51 »
carb cleaner! & and lots of it!!!
Get a flat head screw driver, rotate and open the ICV.
Fill with carb cleaner, and leave for 5 mins. Shake it about and empty, then spray more carb cleaner! use a cloth to clean the bigger pipes.
« Last Edit: 01 July 2007, 20:04:28 by tunnie »
« Reply #2 on: 01 July 2007, 20:07:18 »
Stick the screwdriver in the pipe on the top right, push in and down. It will open the ICV. spay the carb cleaner in until its full.
Leave it standing up for a while  :y
« Reply #3 on: 01 July 2007, 20:54:02 »
NO - DO NOT DO THAT.....you risk damaging the valve face and causing it to stick.....to open the valve, insert a small screwdriver in the front opening and slide the valve body round by pushing against the letters cast into the body...
Its worth realy soaking it well......fill it up as much as you can with carb clenaer and then cover the two openings with your finger and shake it.......lube with a light oil afterwards.
Sometimes a small paintbrush is useful for getting some of the crudd off.
amba
  • Medway towns
    • German V6
« Reply #4 on: 01 July 2007, 21:27:27 »
Thanks guys for advise..will get some carb cleaner in morning from Halfords and do as advised..do i just fill it from top pipe entry as per photo and just stand on end for several minutes..then shake and empty?where does the oil then go and how much?  assume it gets blocked up with burnt oil etc so could have been my erratic tickover??
gizza
  • baildon essex
« Reply #5 on: 01 July 2007, 23:21:31 »
oil goes in the same place your spraying the carb cleaner and put some in and give it a good shake then remove exces
« Reply #6 on: 01 July 2007, 23:41:48 »
When i cleaned project A's V6 ICV that valve face in the right tube was covered it kak, had to scrap it off. I found it easier to rotate the ICV though that pipe than the top pipe.
But advice taken, next time i will use the top pipe  :y
hotel21
  • The Kingdom of Fife
« Reply #7 on: 02 July 2007, 00:03:22 »
Wooden lolly pop stick......   :y
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #8 on: 02 July 2007, 11:17:08 »
Thats a terrible thing to call Tunnie  ;D
Pete Elite
  • Uxbridge, Middlesex
« Reply #9 on: 02 July 2007, 11:53:36 »
Magic  ;D ;D ;D ;D ;D ;D
« Reply #10 on: 02 July 2007, 11:54:33 »
Markie
« Reply #11 on: 02 July 2007, 13:08:10 »
Sorry Tunnie...the conversation flow seemed to direct that at you rather than IACV  ;)
amba
  • Medway towns
    • German V6
« Reply #12 on: 02 July 2007, 17:03:52 »
Thanks for info guys...all clean and working fine so expect issues were 6 of 1 and half dozen of other..anyway icv all cleaned and lubed and seems to tick over at steady 650 rpm with a/c on ...thanks again.andrew
Page created in 0.226 seconds with 20 queries.
