Author Topic: Done the breathers... but....  (Read 5862 times)
    • 530D M Sport, 330i Coupe
« on: 02 July 2007, 10:58:51 »
Did the breathers as per the maintenance guide on here, quite easy when you have a go! Breather system appeared relatively clean but carried on anyway so I can practice for the next time.
Only problem is... There seems to be a slight hissing sound from the nearside of the plenum at idle, it's refitted correctly and all the pipes are refitted correctly (i've double checked). Now TBH I can't remember if it did this before!
The other problem is I seem to have lost 7mpg! though I have been flooring it, checking the multiram is working. Related problem? some sort of Air leak?
Help!
Thanks!
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: Done the breathers... but....
« Reply #1 on: 02 July 2007, 11:14:39 »
Indeed an airleak retrace your steps - its something simple. :y
Check every jubilee is tight every hose is on and every connector clicks into place.
Also check idle control valve is in tight and clean.
If you still have problems post back and we can move on from there to help you resolve..
Dazzler
  • Haverhill, Suffolk
« Reply #2 on: 02 July 2007, 11:56:03 »
If you find no problem with the pipes it might be th eplenum to throttle body o-rings. If you are struggling spray some carb cleaner around the area, it will soon find the air leak ;)
« Reply #3 on: 02 July 2007, 11:59:56 »
Can't check until tonight but I have got those on order from the stealer... did smear them with oil to try to get them to re-seal
Owen
  • Milton Keynes
« Reply #4 on: 02 July 2007, 12:16:42 »
Mmmmm I done my breathers last week, andafterwards my MPG was good around town, now mine dropped to 19, and thats driving it really gently! :o
« Reply #5 on: 02 July 2007, 12:56:31 »
Being the facelift with a 'droop snoot' plenum and no EGR, It doesn't have an ICV.
Markie
« Reply #6 on: 02 July 2007, 13:05:00 »
then that eliminates IACV  ;D still got to be something simple that hasnt gone back correctly...
« Reply #7 on: 02 July 2007, 13:29:58 »
It's no good.... I'll have to leave work early!!!!
« Reply #8 on: 02 July 2007, 13:42:57 »
Yes.....check everything thta was removed....i.e.
Are all the vac pipes re-fitted
Is the brake servo pipe tightened up
Are ALL of the rubber seals present on the inlet to plenum joints.
Is the multiram working ok
« Reply #9 on: 02 July 2007, 14:29:34 »
Multi Ram seems fine, seems smooth in all levels of acceleration. The only thing I did notice when I took the plenum off was the Brake Vacuum fitting in the plenum moved, I tightened it back up but didn't overly do it as the plenum is alloy.
The hissing noise does seem to be from that area but not sure what else should I look at?
Won't be able to look at this until I get home at 9pm tonight and will then have to wait for the engine to cool..... arggghhhh
« Last Edit: 02 July 2007, 14:30:51 by VXL_V6 »
« Reply #10 on: 02 July 2007, 14:44:06 »
Does anyone have the part number for the six 'O' rings between the plenum and the six inlets?
May as well get some more before I take the plenum off again....  :'(
Dazzler
« Reply #11 on: 02 July 2007, 19:22:40 »
The part numbers are in the maintenance guide for the cleaning the breathers ;)
« Reply #12 on: 02 July 2007, 20:50:06 »
You took the plenum off?  :o
If so, check the 6 large o rings underneath - they can go hard and not reseal....
« Reply #13 on: 03 July 2007, 08:29:50 »
Hopefully the stealer will have the O rings today, I did lift it again last night and flipped over some of the 'O' rings and coated them with oil again. Still the same!
All the other connections seem tight (Brake vacuum, multiram pipes, throttle - bagpipe links)
Got this afternoon off (if the O rings arrive!) so i'll take it all apart (3rd time lucky) and look again.
The post from Owen seems along similar lines and i'm wondering if when I was unbolting the throttles if I caused some damage to the rear multiram link. IMHO the Multiram seems fine though...... Maybe I need a second opinion!
Anyone close to Solihull (about 4 miles from the Town Centre?) or I could travel to you?
The 'O' rings listed in RMcB's guide are for the black breather boxes to plenum and throttle, the p/n's I was after were for the six required for plenum to inlet.
Wish I'd left the &*(&(*& plenum on now! Live and Learn I suppose!
« Last Edit: 03 July 2007, 08:51:10 by VXL_V6 »
« Reply #14 on: 03 July 2007, 08:48:57 »
One option might be to drive up the M42....
