Author Topic: Done the breathers... but....  (Read 5866 times)
    • 530D M Sport, 330i Coupe
Re: Done the breathers... but....
« Reply #15 on: 03 July 2007, 08:52:51 »
Not a problem! Would perhaps prefer to have someone watch me have a go at this and point out what i'm doing wrong rather than do this again for the third time and make it even worse!
Kaycee
  • Doncaster
« Reply #16 on: 03 July 2007, 10:21:49 »
must say i did my breathers yesterday i plucked up courage after so many good guys on here said how easy it was 2.5 cdx and was easy but my pipes were clear but the breathebox large pipe had plenty of crud in it but i too have a small prob its ticking over about 750 but used to be about 600 could i too have a problem but having said that it runs perfectly
Robert
There is a tide in the affairs of man if taken at the flood will lead on to greater things
« Reply #17 on: 03 July 2007, 10:24:50 »
Any loss of MPG?
mahony
  • london
    • omega elite 3.0
« Reply #18 on: 03 July 2007, 10:45:12 »
When i did my breathers several weeks ago i too had a loud hissing noise but mine was coming from under the ecotec cover,and found seal 90467543 damaged as it had become hard and broke on reassembling the ecotec covers (mines in two parts),£1.16p from vauxhalls,also found out what was causing my eml to flicker,the plug to the rear multiram was actually off,i do not know how i missed that but there you go,i replaced all the seals on the ecotec cover for piece of mind,hope you manage to sort it.
« Last Edit: 03 July 2007, 10:47:30 by mahony »
« Reply #19 on: 03 July 2007, 16:25:18 »
Right! dismantled it all again and put six new 'o' rings on, carefully (is there any other way?) reassembled it all triple checking every connection and the his is still there....
As I said, the multiram seems fine so i'm at a loss.....
Maybe the hiss was always there.....?
Kaycee
  • Doncaster
« Reply #20 on: 03 July 2007, 16:27:49 »
Not fully checked mpg but will on next long run i used to get 31 on run 25 knocking about all in all im impressed with that as my last car ultima couldnt manage 19
« Reply #21 on: 03 July 2007, 16:36:13 »
Would say I got about the same but I think it's dropped off since I cleaned the breather system. When I heard this slight hiss I presumed I had some sort of air leak....  Not 100% convinced now.....
