Author Topic: drinking oil  (Read 3978 times)
Markjay
  • London
Re: drinking oil
« Reply #15 on: 03 July 2007, 23:23:13 »
...Does anyone know if the quality of oil (e.g 0/40W, 10/40W, fully synthetic, semi synthetic...) affects the consumption?....
In principal oil consumption with thinner oil should be higher....
So 5W-30 may consume more than 5W-40 when the engine is hot, and 0W-40 may consume more than 10W-40 when cold... and 5W-30 more than 10W-40 both when hot or cold....
Having said that, as mark DTM pointed out, slight oil consumption is actually good for the engine, so if the consumption does not exceed the manufacturer's spec I wouldn't suggest to change the oil viscosity to 'compensate'. Going for thicker oil is only recommended in high-milers with excessive oil consumption due to engine wear.
As for semi-vs-full synth, this by itself should not make a difference as long as the viscosities are the same, though full-synth tend to have lower 'W' viscosities than semi-synth - the typical semi is 10W-xx while the typical full is 5W-xx or 0W-xx. So it is possible that oil consumption with full-synth will be higher when the engine is cold due to the lower 'W' value.
This is something I will be looking at soon - as mentioned earlier I am currently loosing oil, which could be either through consumption or though a yet-undetected leak. Once I had a good look for leaks again, I will try switching to semi-synth - I have been using using full-synth for the past 15k - if the oil lose stops than at least I will know I have no leak... as said I don't actually mind if the engine consumes some oil, I just want to know for sure if the oil lose is due to consumption or leak.
Alas, no more Omegas....
Taxi_Driver
Re: drinking oil
« Reply #16 on: 04 July 2007, 05:38:05 »
Hi,
Mine has approx. the same oil consumption (1l for 1k). I use a 10/40 castrol oil and change it every 10k.
mbraz
The back of the manual gives the consumption at 0.6 litrs/1000km so would say your probably bang on for consumption :y
That imo is a vx get out clause......so if your sold a 'pup' that drinks the stuff you carnt go back and complain/ask for a new engine under warranty. I think that is excessive use.
mbraz
  • Hungary
Re: drinking oil
« Reply #17 on: 04 July 2007, 08:02:31 »
To be honest I do not really care at the moment about the oil consumption, I have several other issues with my babay. Actually I purchased it with 105k km and the oil consumption remained the same over the past 30k km. It is between 1-0,5 l for 1k km. Now I am considering changing it more frequently, and I think I will change it in every 5k. I am not sure yet but it feels that breather cleaning decreased the oil cons in my case too.
Actually, I was considering the get the whole engine renewed in the autumn. New gaskets, new rings etc. It would cost 1k but I think it worth it because the car is in a very good condition overall except the engine. I will see.
Page created in 0.023 seconds with 20 queries.
