Author Topic: Larger Mystery Pipe !  (Read 1862 times)
duggs
  • Felixstowe
    • BMW 3.0 Sport
« on: 02 July 2007, 22:48:54 »
Heck !   Another pipe question.
Looking back towards the HBV I've found a pipe, about  10-12mm wide, shiny that is just sitting there.
Is this the breather pipe I read about that comes from the auto transmission...Its just I read somewhere on here that within the engine bay we'll find a pipe thats "open" and its meant to be so...
Please confirm !
« Last Edit: 02 July 2007, 22:56:45 by duggs »
cdx25
  • Plymouth, UK
Re: Larger Mystery Pipe !
« Reply #1 on: 02 July 2007, 22:55:50 »
Looking back towards the HBV I've found a pipe, about half 10-12mm wide, shiny that is just sitting there.
Please confirm !
If yours is auto there is every chance that this is the breather....  should be secured so it doesnt fall down.
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #2 on: 02 July 2007, 22:58:50 »
OOOOOOO okey dokey..Thank you. So its roughly in the right position to be that then ??
Tis just that it looks a little strange sticking up....so the air rises I guess.
I'll secure it..
cdx25
  • Plymouth, UK
« Reply #3 on: 02 July 2007, 23:03:47 »
I'll secure it..
Assuming nobody has shortened it, it might not be a bad idea to point the pipe (ie open end) down if you have the length - I cable tied mine in the shape of an upside down J if you see what I mean.  Might help keep the crap out of it.  Dont want to tie it too low as I think I remember reading on here somewhere that it might syphon otherwise.  Sure someone will correct me if I got that bit wrong.
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #4 on: 02 July 2007, 23:27:00 »
Good point CDX25....I'll play with my pipe tomorrow after work  ???
Markjay
  • London
« Reply #5 on: 03 July 2007, 23:47:19 »
...you could try putting a very small K&N on it... I did it with an engine cam breather on another car once (after disconnecting it from the carb because it was throwing-up muck into it!). Engine breathers do suck-in, but I don't know about autoboxes.. also not sure if it is really an issue, i.e. that dust/muck actually gets into the ATF through the autobox breather...
Alas, no more Omegas....
spookyman60
  • mansfield
« Reply #6 on: 04 July 2007, 03:01:49 »
yes it is an issue if grit and much gets in as it is abrasive and will wear the internals like putting silicon sand in petrol tanks it doesnt take much to rip the injectors
« Reply #7 on: 04 July 2007, 08:09:29 »
as its left open, i would presume that either the other end it filtered, or Vauxhall don't believe its position will allow much ingress...
