Author Topic: Front Top mounts Replacement Info  (Read 2488 times)
Craig_R
  • Watford
« on: 03 July 2007, 09:23:48 »
Does anyone have some photos of the front top mounts, I have to replace mine And I would not mind seeing some picys of them before i try and figure out how to remove mine, and find out what part has failed. I am kind of working in the Dark here As I have never done anything like this before  :-[
Craig
Mod's
[To be Fitted]Reverse Sensors
Re: Front Top mounts Replacement Info
« Reply #1 on: 03 July 2007, 20:39:52 »
LOL, we don't have access to your E drive ;)
Tafty
  • Liverpool
  • This week I am no longer the owner of a miggy!! :(
« Reply #2 on: 03 July 2007, 20:47:24 »
god loves a trier though :y
pete1666
  • Bridgwater Somerset
« Reply #3 on: 03 July 2007, 20:56:41 »
Hi This link should show you what you need well here`s hoping.
http://photos.yahoo.com/pete1666@btinternet.com.
Craig_R
  • Watford
« Reply #4 on: 03 July 2007, 21:16:14 »
Thanks Pete  :y
If these are your Top Mounts could you take the Mounts to bits and photo them in parts for me PLEASE I just want to see how they go together so its easier for me when i replace mine
Thanks
Craig
Mod's
Tafty
  • Liverpool
« Reply #5 on: 03 July 2007, 21:46:27 »
Thanks Pete  :y
Thanks
Craig
Doesn't dismantling these from the car and subsequant re-installation also requires a reset of the geomtery and camber? Not sure if your aware of the potential add on jobs for this job - will stand corrected if talking a load of kak :-/
Martin_1962
« Reply #6 on: 03 July 2007, 22:05:41 »
Thanks Pete  :y
Thanks
Craig
That is no problem for him he lives near Wheelsinmotion
pete1666
« Reply #7 on: 03 July 2007, 22:45:48 »
Thanks Pete  :y
Thanks
Craig
hi sorry cant take apart as i dont have spring compressor, and these are going on to
my car soon as the spring has broken on mine, but if get the other one off
sooner i will see if i can find a spring comp from a friend. Looking at it its just a matter
of stripping it down changing the top mount then re assembling.
When you put them back on the car, get new bottom bolts as they are stretch bolts.
Cheers Pete
« Last Edit: 03 July 2007, 22:48:43 by pete1666 »
« Reply #8 on: 04 July 2007, 08:02:08 »
Thanks Pete  :y
Thanks
Craig
Cheers Pete
Also will need camber reset as well....
Craig_R
  • Watford
« Reply #9 on: 04 July 2007, 09:27:46 »
Thats Ok Pete :)
Am I going to need Spring Compressors to replace the top mounts ? After Chatting At the Tidworth Meet I did not think i was going to need them Am I wrong I dont fancy a face full of Spring when changing them
Craig
Mod's
« Reply #10 on: 04 July 2007, 09:31:36 »
Thats Ok Pete :)
Craig
Its a while ago I changed my shocks, but seem to recall that spring sits against bearing, so yes, compressor required...
