Author Topic: should air be coming outa here  (Read 5136 times)
Owen
  • Milton Keynes
« on: 02 July 2007, 19:12:54 »
Well should it?
 been following the vac hoses for me multiram issue, and air is hissing out from this hole!
Its the back of this thing that this pipe goes into ;)
All he vac pipes seem to be fine, traced them all, no leaks, but still no rams
« Last Edit: 02 July 2007, 19:15:11 by Owen »
duggs
  • Felixstowe
    • BMW 3.0 Sport
Re: should air be coming outa here
« Reply #1 on: 02 July 2007, 19:25:18 »
Owen !  Not sure why you haven't had any/many replies but as far as I know...No ! A vac pipe DOES fit in to that position. I swear its one that comes from the front....others should confirm which one....If you don't get a confirmed answer..get back to me and I'll pop out to check on mine.
Owen
  • Milton Keynes
« Reply #2 on: 02 July 2007, 19:41:54 »
cheers duggs :y
Owen
  • Milton Keynes
« Reply #3 on: 02 July 2007, 20:03:24 »
Yep theres a vac pip goes to this unit, as in the pic, but air is hissing out of the back part of as in the pic.
Just hd another look at it, too of the air from the front t-fitting and give it a blow! Yup air hissing from the back of that thingy! When I put my finger on the hole and whilst blowing the tube there is no airflow foward or backwards :-/
« Last Edit: 02 July 2007, 20:20:48 by Owen »
Owen
  • Milton Keynes
« Reply #4 on: 02 July 2007, 21:17:26 »
Right recon I have fixed it, getting the hang of this stuff a little! ;)
The two vac pipes that run into the rear bit were on the wrong way around according to this pic I found in the maintance guide!
SO I swaped them round so the small pipe ran from the back as in the pic :)
Now 1 major thing happened when I tried it, the vacs in the right place must have powerd up the flux-capacator is it goes like a fakin rocked! It wasnt slow before, but now, i nearly wet me pants 8-) 8-)
2 other things though, not sure if this has sorted the multiram out,  though its just to dam dark to see at the min, and me torch battrys are flat ;D
Now going back to that hole at the back of the thing that the 2 vacs go into, well thats hole is still hissing air! Is it meant to his air? I just dont know :-/
But performance wise,  :o :o :o :o :o :o 8-) 8-)
Of course all the incorrect vac piping must have been done before I got the car?????? :-[ :-[ :-[
Yes right , of course it was! ;D
« Last Edit: 02 July 2007, 21:20:35 by Owen »
« Reply #5 on: 02 July 2007, 21:48:41 »
Of course it will, the multrams are working.....as said in numerous posts, the vac feed must go to the nose of the vac solenoid as the side outlet vents to atmosphere when the valve is shut.
Owen
  • Milton Keynes
« Reply #6 on: 02 July 2007, 21:54:54 »
I know, ive read it that how I finaly sussed this out mate, through reading posts and trying to follow the advice of you guys.
Im just starting to get me head round whats under the bonnet and makes it work  :-/
Any ideas about the hissing valvey thing? :-[
« Last Edit: 02 July 2007, 21:58:00 by Owen »
« Reply #7 on: 02 July 2007, 21:59:09 »
Is air coming out of the arrowed point or is it sucking in....
Owen
  • Milton Keynes
« Reply #8 on: 02 July 2007, 22:07:05 »
Its blowing, coming out of the hole
Owen
  • Milton Keynes
« Reply #9 on: 02 July 2007, 22:37:18 »
Does all of this go towards me comsumption problem of 19?
cdx25
  • Plymouth, UK
« Reply #10 on: 02 July 2007, 23:07:18 »
I get about 17 out of mine... >:(  Maybe I ought to go outside and check those pipes  :o
Owen
  • Milton Keynes
« Reply #11 on: 03 July 2007, 10:55:50 »
at 17 i recon you might have an issue there mate ;)
« Reply #12 on: 03 July 2007, 10:58:39 »
So, what your saying is that there is air blowing out of one of the multiram solenoids?
    • 530D M Sport, 330i Coupe
« Reply #13 on: 03 July 2007, 10:58:45 »
Blimey!  :o I'm getting 25 out of a 3.2.........was getting 30  :'(
I must drive like an oap!
Owen
  • Milton Keynes
« Reply #14 on: 03 July 2007, 11:05:56 »
Yes matey :) Air blowing out as per pic
« Last Edit: 03 July 2007, 11:46:29 by Owen »
