Author Topic: Heater Problem / Coolant Loss - HBV?  (Read 1573 times)
DJ Pete
  • Chelmsford, Essex.
« on: 04 July 2007, 11:00:33 »
I seem to be losing coolant intermittently, sometimes none for a week, then the expansion tank can be empty after a 10 minute journey.
Also, with the aircon off and the heater controls set to cool, the air coming out of the vents is still fairly warm - warmer than ambient temperature.
Is this likely to be the HBV?
Thanks in advance.
Pete.
Re: Heater Problem / Coolant Loss - HBV?
« Reply #1 on: 04 July 2007, 11:02:04 »
Yep....HBV....we seem to be having a few of these fail today!
« Reply #2 on: 04 July 2007, 11:14:34 »
Dunno what its like your way, but quite warm here today, sunny even. Wonder if people are firing on the A/C today....
« Reply #3 on: 04 July 2007, 11:21:29 »
Lucky you! It's about to P!$$ down here... For a change!  ;)
Edited to say: I guess if the weather is borderline "A/C plus heater" and "A/C without heater", as it has been here on the occasions when it hasn't been "bilge pumps flat out", then HBVs are likely to be exercised a little more than usual and the weak ones will let go.
« Last Edit: 04 July 2007, 11:23:36 by Kevin_Wood »
