Author Topic: Oil under pressure  (Read 1424 times)
chrisK
Oil under pressure
« on: 05 July 2007, 22:02:11 »
Omega 2.5 v6 cdx auto saloon about 1998 engine replaced about 2 y ago AFAIK.
I suspect because of blocked breather tubes and probable rocker gasket failure. Hence a build-up of pressure in the oil system, oil leaks, clean dipstick, a little mayo only on the oil filler cap. Runs happily in town as long as the dipstick is not pushed down, releasing the pressure, and oil is not lost.
120 miles on the motorway at 70mph and all the oil is forced out of somewhere underneath with the dipstick in. Dipstick out, town driving and no oil loss. No oil in coolant.
Got us back from B'ham to Worthing (174m) at 50mph max no problem with dipstick out, and just half a tank of petrol used, oil went down from max to min, sprayed out through dipstick pipe,and  the engine compartment is now a little greasy. No loss of power problems, but slightly squidgy brakes under current circumstances.
Looking through your excellent maintenance posts, I think I can handle this myself, unless someone here thinks that a different cause is likely, in which case I would appreciate any comments.
Really need an estate, and have seen one also in need of repair with a sudden coolant loss - HBV problem maybe - any idea of approximate costs to repair?
thanks,
Chris
« Last Edit: 05 July 2007, 22:24:29 by chrisK »
RolandL
  • Doncaster
    • M/facelift 2.5 V6 Elite
Re: Oil under pressure
« Reply #1 on: 05 July 2007, 22:07:48 »
I'm sure an expert will be along soon to talk to you about Oil.   :)
A new hbv will cost £28 +vat, (£25 with trade card)  it's a bit fiddly to do but straight forward
The faster you go the bigger the grin.  Trade card user.
chrisK
« Reply #2 on: 05 July 2007, 22:15:23 »
thanks for the information, Roland
« Reply #3 on: 05 July 2007, 22:16:15 »
If the oil is under too much pressure, its likely to be with crankcase breather system.
As a starter, clean out the breathers as you have found. Clean the throttle body whilst you are at it...
« Reply #4 on: 06 July 2007, 08:18:54 »
Yep....CLEAN THAT BREATHER SYSTEM OUT!
There is info on how to in the maintenance guides.....
