Author Topic: Reverse Sensor Painting  (Read 2069 times)
Craig_R
  • Watford
« on: 05 July 2007, 19:11:52 »
Just got some Reverse Sensors for the car and read through the Docs that came with it and it said pick the right colour senors for your paint  :-? well these sensors are black and it does not say anything about not being able to spray them the right colour.
Is it possible to knack them by spraying them ? will the ultrasonics not pass through spray paint ?
I am going to spray them before i drill holes in my rear bumper to see if they still work.
Has anyone sprayed reverse sensors and them not work after painting ?
Craig
Mod's
[To be Fitted]Reverse Sensors
Re: Reverse Sensor Painting
« Reply #1 on: 05 July 2007, 19:16:43 »
Craig
Yes, one of mine failed about a week after painting - it was the one I may have sprayed too much (the aerosol spat out a blob (probably didn't shake enough))
You know the score - a few light coats, should be OK.
« Reply #2 on: 05 July 2007, 19:50:06 »
I found the secret was to rub them first with a green pan scourer to get a good key, a few coats of colour followed by a few coats of laquer.....then I removed the paint from the rubber suspension ring on them (it just peals off)......
« Reply #3 on: 05 July 2007, 20:38:16 »
And exactly the advice I took successfully, with the exception of the spray 'blob' on one of them.
Craig_R
  • Watford
« Reply #4 on: 05 July 2007, 22:19:21 »
Ill be spraying very lightly then  :)
I did try them with two plastic bags over the sensor and it stil worked so I hope it should be ok.
I did measure with a tape measure to compare the distance between the two and the sensors were 10 cm out exactly ie it said 90cm when it was 100cm and i cant find an adjustment to change it Ah Well
Mod's
Boiler Man
  • Sale, Manchester
« Reply #5 on: 06 July 2007, 10:48:17 »
Hi Guys
Sorry I don't want to hijack the thread, but which make of sensors did you use?
I found some on the web a while ago, that were recommended on the forum, but now I've got around to doing it, I can't find them. :(
« Last Edit: 06 July 2007, 10:48:40 by Boiler_Man »
Omega 2.0 DTI GLS Estate 99 Gold & Omega 2.2 DTI CDX Estate 03 Silver. Just need a Bronze one now for the full set.
« Reply #6 on: 06 July 2007, 10:55:14 »
Hi Guys
I just used some cheapo ebay ones, about £20.  I had to search around a bit, as I only wanted a beeper, not a chaved up display.
