Author Topic: omega 2.0 16v cdx! nothing but ****ing trouble  (Read 6240 times)
VX1
  • Reading, Berkshire
Re: omega 2.0 16v cdx! nothing but ****ing trouble
« Reply #15 on: 05 July 2007, 17:40:50 »
Try this thread for cam cover gasket replacement.
http://www.omegaowners.com/forum/YaBB.pl?num=1180463563
Once you have done that then you can replace the cam sensor which you can do once you have replaced the cam cover back onto the head. Don't forget to clean all the breather's and clean the ICV, you will get better performance and fuel consumption. Also remember to check the metal breather to the left of the engine where the small bend rubber hose is. Remember to stick with it and you will have a car running well and long driving benefits, you will come across things that will fail but that is due to wear and tear. Yes you do need small deep pockets for these car's I'm afraid.
« Last Edit: 05 July 2007, 17:43:05 by vauxhallomega1 »
Vx Trade club card holder
Halfords trade card holder
holey head
  • leeds uk
  • i'm a new dad
« Reply #16 on: 05 July 2007, 17:52:12 »
code i got was
105105
103410
that just kept repeating
ouch my head hurts! i'll try and remember to wear my helmet next time i'm out on the quad!
holey head
  • leeds uk
  • i'm a new dad
« Reply #17 on: 05 July 2007, 17:53:38 »
don't suppose any1 has a picture of which the breathers are? sorry i bit thick lol
VX1
« Reply #18 on: 05 July 2007, 17:58:09 »
When you look at the cam cover the breather's are to the left that are conected to the cam cover. One is thick the other is thin and the other one which I said is at the rear to the right, you can't miss it.
holey head
  • leeds uk
  • i'm a new dad
« Reply #19 on: 05 July 2007, 18:01:17 »
lol is easiest way to get them off wi mole grips?
« Reply #20 on: 05 July 2007, 18:24:45 »
code i got was
105105
103410
that is actually 0340 (0 is 10 flashes) which is cam sensor....
That will lower the rev limiter, so change it :)
To clarify, do you currently have oil in the spark plug wells?
« Last Edit: 05 July 2007, 18:25:58 by TheBoy »
holey head
  • leeds uk
  • i'm a new dad
« Reply #21 on: 05 July 2007, 18:29:13 »
yes i do cheers
« Reply #22 on: 05 July 2007, 18:32:10 »
yes i do cheers
Try and get as much out as possible, using kitchen roll etc.  Then clean breathers and throttle bodys, then see if the oil returns....
Let us know how you get on.
(leaving oil in there will ruin the plug leads)
holey head
  • leeds uk
  • i'm a new dad
« Reply #23 on: 05 July 2007, 18:41:53 »
cheers you guys. your all great!
will keep you's informed of my progress and will try to help others if i can!!!
cheers steve
« Reply #24 on: 05 July 2007, 18:42:25 »
cheers steve
Good luck :y
holey head
  • leeds uk
  • i'm a new dad
« Reply #25 on: 05 July 2007, 20:47:21 »
oooooops just started taking breather pipes off and one snapped!!!!
there are 2 nextto each other on left hand side as you look under bonnet. it's the small one. how important is that one? where does it connect to???
cheers
holey head
  • leeds uk
  • i'm a new dad
« Reply #26 on: 05 July 2007, 21:44:55 »
the small pipe on the left hand side
nixoro
  • Hitchin, Herts
« Reply #27 on: 06 July 2007, 16:35:26 »
cheers
This attaches to the throttlebody just beneath the injector rail, all the breathers are important and a snapped or cracked breather will cause problems.
