Author Topic: DIS Pack?  (Read 2000 times)
ians
  • Reading
DIS Pack?
« on: 08 July 2007, 13:18:32 »
I have now concluded that my 4 pot is not firing (properly) on cyclinder 1
- inspecting the plugs after a run, 2,3,4 all look fine grey/tan deposit as normal.  No 1 is damp.
- looking down plug hole, no 1 is distinctly wet (the others look dry)
- pulling no.1 lead does not affect the engine running (altough the lead does arc to the block).  2,3,4 upset it as expected.  So I conclude that no.1 is not firing anyway, hence no change.
I have new leads, and known good plugs (I swapped 1 and 2 just to confirm with same result above).
So its only the dis pack left on the HT side I think.
I have never touched the dis pack before on any Omega so would appreciate opinions.  Is it possible to inspect the dispack internally or is it a sealed unit as it looks?  (Its completely dry BTW,  although is probably original and 13 years/180k old).
My other theory is that no.1 injector is faulty/blocked (and that the dampness is oil residue that I was unable to clean out of the plug wells).  Feels unlikely though.
I know that oil in plug wells can see off the leads.  Can it also damage the dispack?
Any thoughts?
Cheers,
Ian
Re: DIS Pack?
« Reply #1 on: 08 July 2007, 13:25:08 »
In this scenario, I attach my timing gun to each HT lead in turn, to see if it's firing..
VX1
  • Reading, Berkshire
Re: DIS Pack?
« Reply #2 on: 08 July 2007, 13:46:49 »
Looks like Ian you need some sort of medic on the case and medication for yourself before you start loosing it slightly. You will sort it very soon I am sure.  :)
Vx Trade club card holder
Halfords trade card holder
Re: DIS Pack?
« Reply #3 on: 08 July 2007, 13:50:46 »
I'm not a million miles away if you lose hope.. I don't suspect loom problems, because it would be missing on more than one cyl..
If all sparks are sparking... may be worth a compression test..
ians
  • Reading
Re: DIS Pack?
« Reply #4 on: 08 July 2007, 20:43:30 »
James,
Could dis -pack fail on one lead only?
I seem to remember Mark saying that a spark in open air does not mean there is a good spark under compression.   Anyway, I am going to recheck that that lead is producing a spark to the block, I may have got that wrong..
Cheers
Ian
Dazzler
  • Haverhill, Suffolk
Re: DIS Pack?
« Reply #5 on: 08 July 2007, 21:43:46 »
Compression check first, nice easy job on a 4 pot. IMHO.
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: DIS Pack?
« Reply #6 on: 08 July 2007, 21:44:56 »
James,
Cheers
Ian
As far as i am aware....yes  :-/ reason being a dispack failing on a v6 can lead to it running on 5...
