Author Topic: Pressures  (Read 2269 times)
miggy
Pressures
« on: 08 July 2007, 20:58:39 »
Could someone advise please.
Whilst towing my caravan I use the following tyre pressures
Origional Tyre size = 225 x 55 x 16 95V = Pressures Front 36, Rear 42. This was going by the manual.
I have since fitted new wheels
Tyre size = 235 x 40 x 18 91W = What would the best tyre pressues be whilst towing.
Also, If I had the 4 wheel alignment done with my new wheels as above, would the alignment be the same or would I need to have it done again if I put my Miggy wheels back on.
Any help on the above would be apprieciated.
STMO123
Re: Pressures
« Reply #1 on: 08 July 2007, 22:56:27 »
Bog off. We're all playing with Ronnie at the mo :P
Baron Von Spongebob
  • South Wales
  • Living the dream
Re: Pressures
« Reply #2 on: 08 July 2007, 23:00:50 »
 ;D ;D ;D ;D ;D ;D
Is the world ready for me..
Timbuk
  • Telford
  • owned a Datsun 120y once!
Re: Pressures
« Reply #3 on: 08 July 2007, 23:00:53 »
Thats Nasty  ;D ;D
Baron Von Spongebob
  • South Wales
  • Living the dream
Re: Pressures
« Reply #4 on: 08 July 2007, 23:05:22 »
When doing tyre pressures you should wear open toe sandals..
Kick tyre until big toe hurts, this indicates enough pressure in tyre.
Hope this helps... ;D ;D ;D
Taxi_Driver
Re: Pressures
« Reply #5 on: 08 July 2007, 23:11:30 »
I wouldnt go putting more than 100psi in them.....otherwise they might go pop!  :y
PS.....Try Martin.....he's one of caravanning experts  :y
miggy
Re: Pressures
« Reply #6 on: 09 July 2007, 15:58:38 »
What a bunch of .............. Thanks for that advice, all had plenty of beer have we.
# ;D ;D ;D ;D
miggy
Re: Pressures
« Reply #7 on: 09 July 2007, 15:59:24 »
You bog off you oldtimer.
 ;D ;D ;D
miggy
Re: Pressures
« Reply #8 on: 09 July 2007, 16:00:46 »
Thanks for those words Taffy, it really helped, I hope you find cupcake soon.
 ;D ;D ;D
Re: Pressures
« Reply #9 on: 09 July 2007, 17:17:47 »
Start off with the pressures used on the 17 inch wheels and watch the tyre wear, if wearing in the middle then up them a bit...
Its going to be trial and error to some extent as the calcs were not done during the design of the car.
Martin_1962
Re: Pressures
« Reply #10 on: 09 July 2007, 19:17:43 »
Use the fully laden values, manual not to hand though
old cruiser
  • Slough
Re: Pressures
« Reply #11 on: 09 July 2007, 19:22:41 »
Mark, don't you mean lower the pressure if wearing in the centre of tyre
miggy
Re: Pressures
« Reply #12 on: 09 July 2007, 20:45:14 »
Do you mean use the fully laden values of the 16" on the new 18" even though the tyre size is different.
Re: Pressures
« Reply #13 on: 09 July 2007, 22:20:36 »
I'd go for the 17" values (32 all round normal, 38F 45R fully laden), and see what wear pattern develops...
