Author Topic: Smoke!!  (Read 1723 times)
megaomega123
Smoke!!
« on: 11 July 2007, 14:48:40 »
Car has taken to smoking. Seems to be almost immediately after starting and continues whilst running. Smoke is coming from drivers side, below rocker cover towards the rear. Looks like oil onto manifold but unsure what could cause this.
I have lubricated ICV and throttle butterflys. Could over lubrication cause this? It started within minutes of doing this. I know the gaskets need doing. Do rocker cover gasket just produce oil in the plug wells or can they leak outside also?
omegalyn
Re: Smoke!!
« Reply #1 on: 11 July 2007, 15:27:30 »
It dose sound like your cam cover gaskets need doing. There is a how 2
Re: Smoke!!
« Reply #2 on: 11 July 2007, 15:44:06 »
Cam cover gaskets can also leak onto the manifold causing quite spectacular smoke.....
megaomega123
Re: Smoke!!
« Reply #3 on: 11 July 2007, 16:36:35 »
That must be what it is then. Oh well only 3 weeks to go then changed.
tyvm all
