Author Topic: Oil Cooler??  (Read 1722 times)
benjamind
  • Manchester
Oil Cooler??
« on: 14 July 2007, 10:28:24 »
I think i know the answer but just after a bit of confirmation;- Car is losing about 1 litre of coolant every 3 weeks or so, i doubt it will be the HBV as JamesV6 changed this approx 2 months ago. Also car seems a bit hot when walking past drivers side after a decent run, but temp gauge remains between 94-97 ish. Any suggestions please??
PS James you may need to get your tool kit ready again.
Re: Oil Cooler??
« Reply #1 on: 14 July 2007, 10:48:43 »
Looks like I may be coming up to manchester for a days consultancy again ;D
Is there any sign of gunge in the coolant tank, or in the dipstick...
and obvious drips on the floor?
Could be the cooler plate, coolant bridge seals, thermostat housing, front / rear transfer pipe.....
benjamind
  • Manchester
Re: Oil Cooler??
« Reply #2 on: 14 July 2007, 11:28:31 »
drips on floor definitely, i will have to check all the other bits n bobs . will post up later
Re: Oil Cooler??
« Reply #3 on: 14 July 2007, 11:38:38 »
Is it dripipng down the passenger side of the bellhousing?
Re: Oil Cooler??
« Reply #4 on: 14 July 2007, 16:40:19 »
Unlikely to be oil cooler failure.  Depending on where leak coming from should help pinpoint...
