Author Topic: Nasty knocking from engine  (Read 5167 times)
Sir Gingerlot
  • Leicester
« on: 14 July 2007, 22:56:03 »
The rattle recently experienced from the camshafts has taken a turn for the worst. Whilst giving it some welly this evening the engine started to knock loudly. Managed to get it home but does'nt sound good.
Any ideas what this might be.
The cambelt was changed recently. Could this sound be caused if it has slipped a couple of teeth.
I didn't notice an engine light whilst it was doing it.
Only other thing I can think I have done recently is spray some WD40 around the crank sensor to clean off some spilt oil.
Any help appreciated.
omegalyn
Re: Nasty knocking from engine
« Reply #1 on: 15 July 2007, 00:30:31 »
Hi there Ong,
Dont know the history of you probs, but I would start by checking the timing marks to see if all is lining up.
Cheers
Lyn
« Reply #2 on: 15 July 2007, 08:52:19 »
DON'T DRIVE IT!
Could be a slipped cambelt, damage may already be done.
If you need help to check it, then yell.
Next job - cambelt cover off, check timing, timing belt, and condition of rollers.
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #3 on: 15 July 2007, 10:02:34 »
DON'T DRIVE IT!
And if your unsure at that point of the timing and what you find under the covers come back on with a picture and we can assist  :y
Sir Gingerlot
  • Leicester
« Reply #4 on: 15 July 2007, 11:25:54 »
Thanks
I will strip down to check cambelt etc. Beyond these checks I will be at my knowledge limit so may need some personnal assistance if possible.
« Reply #5 on: 15 July 2007, 11:27:30 »
Thanks
Totally possible ;)
sassanach
  • trowbridge
« Reply #6 on: 15 July 2007, 11:34:51 »
sounds more like a big end has let go,(dull very nasty knock sounds like its coming from the very bowels of the engine)camshafts more of a rattle :(
Sir Gingerlot
  • Leicester
« Reply #7 on: 15 July 2007, 16:08:19 »
Checked the cambelt and all looks good. The markings are lining up and there doesn't appear to be any unusual resistance when rotating the crank.
If it is one of the big ends, is this likely to be an expensive job. If so there could be a nice project car up for sale for some body.
The owner before me had the head gaskets replace last October. Is it possible that the garage could have done something wrong.
Sorry for all the questions. My initiation to V6 ownership is not going well. Owned a 4 pot Omega for 6 years and never had any problems.
Thanks for any help.
wastedperfection
  • Stoke on Trent
« Reply #8 on: 15 July 2007, 16:19:31 »
is my first v6 with no problems , you just might have been unlucky.
Sir Gingerlot
  • Leicester
« Reply #9 on: 15 July 2007, 21:22:54 »
Anybody got an idea of how I check if it is a big end failure. Is it as simple as just removing the sump?
« Reply #10 on: 15 July 2007, 21:48:16 »
Best way is to get someone to have a listen. If it's a heavy knocking, sensitive to engine load it's something in the bottom end. Tappets will be a light rattling, normally not sensitive to engine load and it'll be obvious that it's coming from the top end. Could be other things, like a siezed little end causing severe piston slap but either way it needs a stripdown if it's not tappets.
Removing the sump won't tell you much, unless to have the big ends out as well. Not sure the whole sump will come off in-situ and if it comes to that you're probably better off swapping the engine for a 2nd hand one, TBH.
Markie
« Reply #11 on: 15 July 2007, 21:56:21 »
....i guess the only goood thing about this is your in the best part of the country for this to happen - theres a good few of our real knowledgeable ones around your area.... :-/
Sir Gingerlot
  • Leicester
« Reply #12 on: 15 July 2007, 22:15:24 »
Thanks for the replies. The noise I heard was a deffinate knocking coming from the engine and not the rattle of noisy camshafts.
I think my first try will be to contact the previous owner and see if I can get his garage to have a look bearing in mind they have not long replaced the HG's. Reading the posts on this site it is not common for pistons or big ends to fail on these cars so I am thinking they may have done something wrong.
Worth a try. Just glad I kept my 2.0l.
Martin_1962
« Reply #13 on: 15 July 2007, 23:28:46 »
How easy are the big end bearings to do?
Took me under two hours to do a Sunbeam once
« Reply #14 on: 16 July 2007, 12:28:11 »
Is it manual, does it go quieter with the clutch pressed?
Any noise reduction with the aircon off?
When the cambelt timing marks were aligned, was the tensioner setting correct?
