Author Topic: Is Traction Control Retrofit Possible???  (Read 2436 times)
kbou55
  • Tipperary, Ireland.
  • Peace, Through Superior Firepower
« on: 14 July 2007, 01:33:37 »
I was wonder if it was possible to fit traction control to a 2000 Omega :question, it the only thing not fitted to my car and id love an excuse to whip out the dash again.
2002 Vectra 2.2 DTI Elite (for work)
2000 Zafira 1.8 Elegance (for the wife and kids)
2000 Honda Pan European ST1100 (for play)
Dave-C
  • Staffordshire
  • The Old Girl
Re: Is Traction Control Retrofit Possible???
« Reply #1 on: 14 July 2007, 05:59:21 »
Pretty sure it's possible, remember reading a thread a bit ago. For what use it is, personally I wouldn't bother with it..   Feathering the throttle's more effective...  I often turn mine off is slippy situations, it takes the drive out of drivability...  However, if you want to do it for doings sake, Go For It!  and best of luck...
DC
« Reply #2 on: 14 July 2007, 10:29:12 »
Technically possible, but practically not worth it....LOADS of work...
« Reply #3 on: 14 July 2007, 16:32:11 »
No, not possible.
kbou55
« Reply #4 on: 15 July 2007, 17:16:00 »
No, not possible.
I hear and tremble, oh knowledgeable one.
Markjay
  • London
« Reply #5 on: 16 July 2007, 16:29:12 »
AFAIK this was standard on V6 models - because the 4-cyl were not powerful enough to generate power slides etc - so it's probably a case of if you don't have it your car doesn't need it...
Then again I suppose it could be useful if you encounter an oil spill or something, but if mr. 14k+ posts says it can't be done, then it can't be done  ::)
Alas, no more Omegas....
« Reply #6 on: 16 July 2007, 16:58:11 »
I've said before that I'm not impressed with the TC system because, in most situations I encounter on the road, it just bangs the throttles shut with very little finesse. It would stop a numpty from pirouetting into the bushes with a bootful of throttle on but not much of a driver aid, IMHO.
However, I had cause last weekend to drive my Omega up the side of a hill on some heathland. No road, tarmac or anything, just a grassy, heathery slope at about 1 in 3 gradient. TC was absoutely fantastic. I thought about zig zagging up this slope to reduce the gradient but decided to try and drive straight up and see how far I got. Just as I got to the point where I thought I was about to run out of traction I felt the ABS modulator start up, the slipping wheel got a bit of braking and It just cruised up. Went up just as easily as my mate's 4x4 and considerably easier than another mate's Ford Focus!
So, with a gradual loss of traction where it gets time to play with the brakes before slamming the throttle shut, It's great IMO.
A retrofit wouldn't work, just buy a V6 :y
« Reply #7 on: 16 July 2007, 18:13:05 »
It is possible to get a good loss of traction on a 4 pot - esp with Tunnies naff tyres ::).  Its also possible to get a good spin from a tractor in the wet with naff tyres ::)
Whether or not it needs is is not the point, drivers should be more careful! If the safety functions come on (TC or ABS), you are driving beyond the capabilities of the chassis in those conditions!
« Reply #8 on: 16 July 2007, 20:49:34 »
So, with a gradual loss of traction where it gets time to play with the brakes before slamming the throttle shut, It's great IMO. ........
Perhaps I should've have more faith in mine then on the very very soggy caravan site in Cornwall. I just unhitched when the TC light started to flash at me, & moved the 'van to the pitch on its mover.  ;) I was concious of not churning up the field.
