Author Topic: misfire and hesitation under load  (Read 6127 times)
Dean
  • Weston Super Mare - UK
« on: 14 July 2007, 17:03:28 »
When my car is under load it seems to misfire and hesitate then off she goes when the revs get up.
I took the earier accessable left two plugs out today and noticed there is oil around them...
Having done a bit of research on here would you say its the camcover gaskets? leaking oil onto the plugs thats causing this problem?
Free Traffic law advice  - Just PM or see the sticky thread in General Chat ! http://www.omegaowners.com/forum/YaBB.pl?num=1177278724 - no liability accepted
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: misfire and hesitation under load
« Reply #1 on: 14 July 2007, 17:08:22 »
Looks like it mate, a new set of plugs would be a good idea too.
Are your leads ok as the oil can fry em.
TuBy's new whipping boy.
Dean
« Reply #2 on: 14 July 2007, 17:14:05 »
I think the leads are ok, but will check when i do the gaskets..
New gaskets and spark plugs needed then..
The first spark plug i cant get out because its really stuck... any advice on how to pursuade it out, Will i do any damage using more force
Thanks
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #3 on: 14 July 2007, 17:20:54 »
Mine were rather stiff but I managed to wind em out with the ratchet, I'm sure one of the more knowledgable ones will be along shortly to advise.
« Reply #4 on: 14 July 2007, 17:23:13 »
The staining on that plug suggests it may have a defective seal between the ceramic part and the metal  :-/ Could just be from the oil though.
Either way, the cam cover gaskets need sorting, the breathers need checking in case this has caused the cam cover gasket failure and I'd put a new set of plugs in while you're at it just to be on the safe side.  :y
Regarding the stuck plug it might be worth giving it a try on both a hot and cold engine. It may be easier to shift when hot.
A little smear of copper grease on the threads isn't a bad idea when you fit the plugs.
Dean
« Reply #5 on: 14 July 2007, 17:25:08 »
The engine was pretty hot when i tried to get it out so might just have to give some....
bigup316
  • oxfordshire
« Reply #6 on: 16 July 2007, 20:27:03 »
i had the exact same problem cleaned icv throttle bodie i had two pipes split changed them both still did it got a new set of plugs and the car run spot on now
Mike Collins
  • North of Bristol
« Reply #7 on: 16 July 2007, 22:20:59 »
I would be very wary of the ht leads, does'nt take much oil to fry them. Patchway Autoparts do set for  a reasonable amount, Bosch from memory.
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #8 on: 16 July 2007, 22:35:42 »
vauxhall leads are dear - but very good - beware of some non vx leads
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« Reply #9 on: 17 July 2007, 00:05:22 »
blue magnecor leads are good but from memory about £130 inc. VAT - still cheaper than Vx ones which are approx. £90 PER SIDE  :o
Markie
« Reply #10 on: 17 July 2007, 11:02:47 »
really? £180 for 6 leads? I`d be checking that dealer against another :-/
Dean
« Reply #11 on: 17 July 2007, 14:58:56 »
One thing i did notice is it misfires considerably less if i use SUPER UNLEADED or higher octane fuels?
Will be going to the VX dealer on Friday to get all the gaskets and new set of spark plugs..
Hopefully the weather will be dry so i can get on with it...
Also hoping that blasted Spark plug comes out with a bit more force... (could i use a lubricant down the hole ...WD40 or something?) or will that get into the engine and cause problems??
Would appreciate your opinions.
Dean
« Reply #12 on: 17 July 2007, 15:14:16 »
A squirt of penetrating lubricant around the plug won't hurt. WD40 is not a good penetrating lubricant, however, IMO. I'd use Plus Gas.
This will relieve any friction from the sealing washer but probably won't penetrate into the thread. Worth doing as it can't do any harm, and don't worry about a small amount getting into the cylinder. Try and spray plenty around the plug and leave it to soak for 15 mins before you try to remove it.
Dean
« Reply #13 on: 17 July 2007, 17:15:42 »
just been and got all the parts..... :o
All the gaskets, with spark plugs....£152.77!!!
that hurt!
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #14 on: 17 July 2007, 17:35:02 »
that hurt!
rather hell, didn't you try asking for trade.
Got a set of plugs, cam cover gaskets & o rings and it only came to £70.32.
Have you tried asking your company mechanics if they can get you VX bits at trade it would save you a fortune.
