Author Topic: To seal or not to seal?  (Read 4029 times)
Golfbuddy
  • Cornwall
  • I'm On An Economy Drive
« on: 18 July 2007, 21:50:59 »
That is the question.
I am going to clean my throttle body and breathers on the weekend as per the maintenance guide. Definately, no excuses rain or shine. I've even ordered the gaskets from Vx dealer today and they will be in on Friday.
The real question is should I use gasket seal on the new gaskets and if so what should I use? Also the recommended torque setting of 9nm for the throttle body doesn't seem very tight and my new torque wrench doesn't go that low. Could I just tighten it carefully and hope for the best?
OK thats two questions :y
[size=24]        [/size][/b]
STMO123
Re: To seal or not to seal?
« Reply #1 on: 18 July 2007, 21:52:26 »
Hope for the best? With an omega? ;D ;D ;D ;D ;D
[size=36]NO![/size]
« Reply #2 on: 18 July 2007, 21:53:50 »
Sealent is not required.
As for the bolts, just nip them up....dont be tempted to make them tight you only need to compress the rubber seal and get the mating surfaces to touch.
« Reply #3 on: 18 July 2007, 21:57:26 »
As MDTM says, no sealent. 9Nm is just a 'nip', easy to strip...
Golfbuddy
  • Cornwall
« Reply #4 on: 18 July 2007, 21:57:44 »
I prefer your answer to STMO123's so I don't need a baby torque wrench then.
And I've just got my third star [smiley=2vrolijk_08.gif] [smiley=2vrolijk_08.gif] [smiley=2vrolijk_08.gif] Life truly is sweet on OOF.
« Reply #5 on: 18 July 2007, 22:00:49 »
As much as I feel that a set of torque wrenches are an essential in all tool boxes given the massive use of alloy parts on modern items....... I like to offer an altenative  as a short term measure.
Craig_R
  • Watford
« Reply #6 on: 18 July 2007, 22:14:26 »
Yep Finger Tight and then Nipped up
And As Said No Sealant needed on the Gasket Which Is just a Paper One on the 4 pot Throttle body just clean the two surfaces well so there is no junk on there
Craig
Mod's
[To be Fitted]Reverse Sensors
Golfbuddy
  • Cornwall
« Reply #7 on: 18 July 2007, 22:34:36 »
Just a thought. Should I use sealant on the breather sump gasket?
« Reply #8 on: 18 July 2007, 22:38:52 »
Whats that then?  :-?
Golfbuddy
  • Cornwall
« Reply #9 on: 18 July 2007, 22:41:00 »
I don't know :'( But i've ordered one from the stealer 'cos it said it in the maintenance guide. :( :(
« Reply #10 on: 19 July 2007, 11:11:46 »
Shouldn't be needed.....
Golfbuddy
  • Cornwall
« Reply #11 on: 19 July 2007, 11:18:30 »
I guess you mean the sealant shouldn't be needed.
Thanks for the reply. :y
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #12 on: 20 July 2007, 06:31:43 »
No, just a new gasket.
I like red cars
Golfbuddy
  • Cornwall
« Reply #13 on: 20 July 2007, 08:01:22 »
Cheers AA.    :)
