Author Topic: Big help please  (Read 4054 times)
megaomega123
Big help please
« on: 19 July 2007, 18:26:32 »
Yesterday, got new exhaust (centre sections), had the plenum off to do breather box seals and broke the rear multiram.
Today, running very bad, when pulling off it putters with very little power this is right through the range at revs below 3000rpm. Once past 3000 it is ok. Would no rear multiram alone cause this? Please help, I don't want to do anything else to it as everytime I do something else happens which is worse than the original problem.  :'( :'( :'(
Dazzler
  • Haverhill, Suffolk
Re: Big help please
« Reply #1 on: 19 July 2007, 18:40:52 »
Yep, afraid so, especially if it now has an air leak where its broken ::)
megaomega123
Re: Big help please
« Reply #2 on: 19 July 2007, 18:42:01 »
No air leak, it is just the connector. Forget the 3000rpm it is right through the revs.
megaomega123
Re: Big help please
« Reply #3 on: 19 July 2007, 18:46:29 »
So rephrase, just with the rear multiram not connected are these symptoms correct?
Re: Big help please
« Reply #4 on: 19 July 2007, 18:57:58 »
With rear multiram not working, power will be down, but not that drastic...
megaomega123
Re: Big help please
« Reply #5 on: 19 July 2007, 19:37:14 »
Multi ram now ruled out as i've swapped it for the air injection one. The exhaust that i had fitted yesterday is kinda ticking on driver's side, centre box. there was also  some water around the seams of the centre box. i took it back and was told to give it a couple of days to settle down  :D So could a faulty centre box cause the above issues?
megaomega123
Re: Big help please
« Reply #6 on: 19 July 2007, 22:33:17 »
Any help pls. Sry to pester but need everything all square by Tuesday for cambelt.
Thanks
Re: Big help please
« Reply #7 on: 19 July 2007, 22:36:13 »
multiram won't cause it to run bad.
Stick a latex glove on the tailpipe, and see how fast it inflates it!
megaomega123
Re: Big help please
« Reply #8 on: 19 July 2007, 22:54:08 »
You and your latex gloves lol. I'm beginning to think you have a fetish lol.  Shall I just let it go until it goes bang?
megaomega123
Re: Big help please
« Reply #9 on: 19 July 2007, 23:00:24 »
Done that, it was about 3 seconds until it went bang. I blipped the throttle lightly and the centre box is popping, sounds really bubbly and a bit rattly.
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: Big help please
« Reply #10 on: 19 July 2007, 23:11:04 »
ack to your exhaust place if you think its not right - third opinion.
so what have you done today work wise? Lets see if we can narrow this power loss down?
megaomega123
Re: Big help please
« Reply #11 on: 19 July 2007, 23:20:25 »
Nothing today, except swap the soleniod valve for the multiram with the one for the air injection. This was done after the problems to try to rectify, but no difference.
Yesterday, just sealed the breather box with latex glove rim until I get parts 2moro. Only major change is the exhaust.
megaomega123
Re: Big help please
« Reply #12 on: 20 July 2007, 11:30:46 »
Ok update on this. All seems well when cold, symptoms of missing appear after 10 minutes of driving and get progressively worse. I seem to have oil leaking on the passenger side at the back end of the manifold heat shield. Could this be the gasket leaking a bit (that i've just changed) and could this cause the missing once warm?
I am desperate  to get this sorted before Tuesday.
« Last Edit: 20 July 2007, 11:32:18 by phate321 »
Re: Big help please
« Reply #13 on: 20 July 2007, 11:45:35 »
Are plug wells filling up still?
megaomega123
Re: Big help please
« Reply #14 on: 20 July 2007, 11:48:44 »
I am just going out to do the bretaher box seals so I will check them and report back.  :y
