Author Topic: help on omega 2.5 v6  r reg  (Read 1424 times)
holyheadman
  • anglesey
« on: 20 July 2007, 15:31:07 »
     please i am in need of some help concerning omega 2.5 v6
      i have just had a full service to see if this would solve the following problem done,
     the engine is idleing at 500rpm and when you start to go it is if the engine is firing on 5 plugs or that it needed new leads also had new gasket put on head due to oil going into spark plugs holes.  garage cannot find the problem so any help please
Re: help on omega 2.5 v6  r reg
« Reply #1 on: 20 July 2007, 15:32:42 »
Leads could be culprit, esp the one that has been baked in oil...  ...failing that, plugs or DIS.
I am assuming EML isn'y on...
wakeyomega
  • Wakefield
« Reply #2 on: 20 July 2007, 15:55:31 »
I also assume it was the Cam cover gasget and NOT the head gasket they changed? Otherwise yo may still have the oil leak, as it will undoubtedly be the cam cover gasket that failed.
Pat
Remember, if you ever need a helping hand, you'll find one at the end of your arm
« Reply #3 on: 20 July 2007, 16:39:42 »
Pat
Cam cover gaskets will be replaced if you do HG...
...how else will you undo head bolts?
« Last Edit: 20 July 2007, 16:40:05 by TheBoy »
wakeyomega
  • Wakefield
« Reply #4 on: 20 July 2007, 16:52:05 »
Posted by: TheBoy Posted on: Today at 16:39
Quote from wakeyomega on Today at 15:55:
Pat
Good point....... and very well made  ;)
What I was also trying to say, but not very well, was did they change the HG in error. But as you say, either way the cam gasket should now be Ok.
holyheadman
  • anglesey
« Reply #5 on: 20 July 2007, 17:56:29 »
    many thanks for your help in this matter i will find out more tomorrow will keep you posted
    thanks again
