Pages: [1] 2 3  All   Go Down
Author Topic: Spark Plugs  (Read 10982 times)
Pride and Joy
  • Bridlington E. Yorks
Spark Plugs
« on: 23 June 2007, 12:54:12 »
Back again - having spent the last few months reading through all the brillians info on this site. Thought I'd do a bit of maintenance and seeing the only thing I haven't done so far is change the spark plugs - was done when I bought the car 9 months ago. Horror of horrors plugs 2 & 3 absolutley drenched in oil. Had no problems starting - but I have always thought the power was a bit low. Any advice would be greatly appreciated
« Last Edit: 23 June 2007, 12:55:44 by Pride_and_Joy »
Regards Peter
Re: Spark Plugs
« Reply #1 on: 23 June 2007, 12:55:44 »
Cam gaskets. Replacement info in Maintenece Guides section. Clean breathers as well.
megaomega123
Re: Spark Plugs
« Reply #2 on: 23 June 2007, 12:57:46 »
Rocker cover gaskets. Same old story. Mine have been leaking for a year and all plug wells fill up every 3 months or so. I have just purchased a baster to remove the oil again.
Plenty of how to's on here when it comes to changing them.
Pride and Joy
Re: Spark Plugs
« Reply #3 on: 23 June 2007, 12:57:52 »
thank you will have a read and sort out - did have horrible thought of piston ring seals etc.
Thanks again
Peter
Regards Peter
Re: Spark Plugs
« Reply #4 on: 23 June 2007, 13:19:11 »
Thanks again
Peter
Its actually not a bad job, looks far more scary than it really is.  The passenger side can be fiddly, and an extra pair of hands to hold the loom out of the way helps...
mahony
  • london
    • omega elite 3.0
Re: Spark Plugs
« Reply #5 on: 23 June 2007, 13:32:25 »
just done my cam gaskets on my 3.0 elite,not too difficult,just be meticulous when reassembling,clean up all traces of old sealent and make sure seal is located properly in cam cover,need a good selection of tools also,took me a day to do which also included cleaning out the breathers and replacing spark plugs.
ps, also only use geniune vauxhall gaskets.
« Last Edit: 23 June 2007, 13:33:28 by mahony »
Pride and Joy
Re: Spark Plugs
« Reply #6 on: 23 June 2007, 13:52:33 »
thanks for all your help everyone - have read the inst and will go and get the new gasket on Monday. Seems fairly straightforward. Still a bit worried about the plug electrodes been covered in oil though??
Thanks again all
Peter
Regards Peter
mahony
  • london
    • omega elite 3.0
Re: Spark Plugs
« Reply #7 on: 23 June 2007, 13:57:10 »
my plug leads where covered in oil too,just sprayed carb cleaner  on them and then dried  with kitchen roll.if the leads are kaput  you will soon know.
Pride and Joy
Re: Spark Plugs
« Reply #8 on: 23 June 2007, 14:01:43 »
no sorry the actual electrode at the tip of the plug - thought the oil must have been in the piston bore
Regards Peter
Re: Spark Plugs
« Reply #9 on: 23 June 2007, 14:03:57 »
Was it the wells that had filled up with oil?
If so, I suspect some ran down plug when you removed them. Try to keep any oil out of the cylinders - the cats won't like it.
VX1
  • Reading, Berkshire
Re: Spark Plugs
« Reply #10 on: 23 June 2007, 15:22:53 »
The cats don't like it, but it is fine all that will happen is you will get alot of blue smoke come from the exhaust no damage is caused just blue smoke. You can also use gasket sealant on the head as well, just smear some sealant around the head then replace the cam cover, bolt it down in the same way as you are bolting the head down in a spiral motion the will give an even join.
Vx Trade club card holder
Halfords trade card holder
Re: Spark Plugs
« Reply #11 on: 23 June 2007, 15:40:31 »
Only use the sealant in places suggested in guide, not all the way round :)
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Spark Plugs
« Reply #12 on: 23 June 2007, 23:03:25 »
The eight Cam Cover Bolts have to be torqued to 8 nm, don't over tighten :y
« Last Edit: 23 June 2007, 23:03:57 by Loo-knee »
Re: Spark Plugs
« Reply #13 on: 23 June 2007, 23:06:43 »
Failing that - a cable tie works well..
ians
  • Reading
Re: Spark Plugs
« Reply #14 on: 23 June 2007, 23:09:01 »
We're talking 4 pot aren't we - so much simpler job. :)
Pages: [1] 2 3  All   Go Up
Page created in 0.022 seconds with 20 queries.
