Pages: 1 2 [3]  All   Go Down
Author Topic: Spark Plugs  (Read 10996 times)
Taxi_Driver
Re: Spark Plugs
« Reply #30 on: 06 July 2007, 19:23:25 »
thanks gus - yes the part number is the same and yes the gasket does look like the one he showed me on the pc - but been a thicky - as the gasket runs round the outside how does that stop the oil getting into the sparkplug wells which are in the middle????
mine is a 4 cyl 2.2 :-[
The gasket consists of more than is shown  :y
Taxi_Driver
Re: Spark Plugs
« Reply #31 on: 06 July 2007, 19:25:28 »
thanks guys - yes the part number is the same and yes the gasket does look like the one he showed me on the pc - but been a thicky - as the gasket runs round the outside how does that stop the oil getting into the sparkplug wells which are in the middle????
is 50ml enough for the job??
Plenty  :y
Re: Spark Plugs
« Reply #32 on: 06 July 2007, 19:28:28 »
you only use a few blobs of sealent...
Re: Spark Plugs
« Reply #33 on: 06 July 2007, 21:25:01 »
50 ml is more than enough and dont smear it all the way around the head, it can create more problems and tops the rubber seal maintining a constant pressure along the long runs. Just put it either side of the cam caps and on the corners of the half moon cut outs at the rear.
Pride and Joy
  • Bridlington E. Yorks
Re: Spark Plugs
« Reply #34 on: 06 July 2007, 23:59:02 »
Thanks guys,
Much appreciated all the help - have taken all on board. Will have a go on Wed - weather permitting.
Thanks again for all your help
Peter
Regards Peter
Pride and Joy
Re: Spark Plugs
« Reply #35 on: 07 July 2007, 06:41:01 »
Just re read the amended version of the maintenance guide for doing the job. I assume that the reference to allen keys is the Torex on my model, but more importantly I missed the bit about "O" rings. Should I have ordered them with the gasket or do they come with it. If I need to order can you give me a part No so that I can ring them this morning.
Typical isn't - the sun is bloody shining - no rain - could have got the job done today - but no gasket till Wednesday. Bet you its Pi**ing down on Wed.
Thanks again  to all
Peter
Regards Peter
Pride and Joy
Re: Spark Plugs
« Reply #36 on: 22 July 2007, 11:37:27 »
Still not had chance to do the job - got all the parts but the weather has been against me. Will let everyone know the outcome
Regards Peter
Pages: 1 2 [3]  All   Go Up
