Author Topic: Which sensor is this then?  (Read 5968 times)
Owen
  • Milton Keynes
« on: 21 July 2007, 16:35:57 »
Changing the pads today and on the pasanger side found this neatly tucked away.
A sensor, but which one? What exactly is it?
nixoro
  • Hitchin, Herts
Re: Which sensor is this then?
« Reply #1 on: 21 July 2007, 16:38:01 »
looks like a broken brake pad sensor :y
« Last Edit: 21 July 2007, 16:38:46 by nixoro »
  • Online Online
« Reply #2 on: 21 July 2007, 16:39:08 »
Passenger side low brake pad warning sensor.  ;) At least it'll never wear though!  ;D
*edit* ... Doh! Beaten to it! ;)  ;)
« Last Edit: 21 July 2007, 16:40:16 by Andy_B »
Owen
  • Milton Keynes
« Reply #3 on: 21 July 2007, 16:48:17 »
Right gotcha :y
Not much of an issue if I dont have the sensor connected then?
Well at least untill i get to the scrapy ;)
Mike Collins
  • North of Bristol
« Reply #4 on: 21 July 2007, 18:31:09 »
The display will probably whinge about brake pad, but brakes should still work!
  • Online Online
« Reply #5 on: 21 July 2007, 18:46:48 »
Right gotcha :y
You'll be very lucky to remove a sensor from a scrap yard car without breaking the pin off, and have what you already have. ;) I wouldn't worry about it untill you next change your brake pads, later cars only have the one sensor anyway.
« Reply #6 on: 21 July 2007, 19:57:19 »
Those front discs look new......
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #7 on: 21 July 2007, 20:37:04 »
....but the pad sensor doesnt  ::)
Owen
  • Milton Keynes
« Reply #8 on: 21 July 2007, 21:29:44 »
There was a horrible sound under braking, exactly like very low pads, went out and bought a new set to pop on and when I got the wheels off the disks and pads were new. Always handy to have a spare set i guess.
But the sound, which sounded exactly like very low pads starting to grind a little, is still there, and would apear nowt to do with the pads and disks!
Done the idler arm recently and I know its all tight under there, so I am not sure what could be causing the sound
« Reply #9 on: 21 July 2007, 21:49:38 »
bearings?
  • Online Online
« Reply #10 on: 22 July 2007, 01:28:28 »
Small stone wedged between the caliper & disc?
x25xe
  • Hayes, Middlesex
  • Avater removed due to size
« Reply #11 on: 22 July 2007, 09:26:28 »
Very likely I would say - I had exactly this on an Astra that I owned once.
Owen
  • Milton Keynes
« Reply #12 on: 22 July 2007, 16:48:57 »
Well I had the calipers off yesturday so if owt was in there i recon it might have gone.
Strange thing i noticed today is that the pasenger side front tyre is getting really chewed up evenly accross the tread.
« Reply #13 on: 22 July 2007, 19:17:44 »
Toe...
Taxi_Driver
« Reply #14 on: 22 July 2007, 19:30:54 »
Toe...
Finger  ;D ....oh sorry thought you were playing a word association game  :-[
Yeah TB will be correct....as i dont know.
Page created in 0.022 seconds with 21 queries.
