Author Topic: Automatic gearbox sluggish  (Read 2078 times)
DESIMUS
  • BELFAST
« on: 22 July 2007, 22:04:50 »
Hi all i am having trouble with the auto box on my 99 3ltr mv6 in the morning its starting off in a lower gear if i change manually its very sluggish at first but its ok after a while. i have already changed the gear oil and altho that did help its still sluggish in the morning.  when changing the oil i found what looked like a washer it was in bits in the oil pan anyone give me an idea what this could be and what to do next? thankx :)
Re: Automatic gearbox sluggish
« Reply #1 on: 22 July 2007, 22:10:18 »
Holding the gearbox in 1st gear from cold is normal behaviour - this is to heat up the cats quicker, hence reducing emissions and saving the planet.
However it would appear your gearbox has dropped a thrust washer, just like my Elite did. Seen this a lot recently.
This means your gearbox is likely to fail very soon, you need a replacement gearbox, or a rebuild of the original one. It WILL let you down.
Sorry mate.
« Reply #2 on: 22 July 2007, 22:24:00 »
That'll be the thrust washer. That box may not last too much longer.....
AndyMV6
  • Wiltshire
« Reply #3 on: 23 July 2007, 19:38:41 »
from what i have read on here, Sassanach is the guy to speak with. Knows theses boxes inside out.
