Author Topic: Whats causing my rough idle..  (Read 2703 times)
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« on: 22 July 2007, 14:53:26 »
Just done breathers, IACV, breather pipes, plenum, throttle bodies and all that Jazz..
Done it 5 times before on rough vauxhalls - every time it has the desired effect ( rock steady idle) so i know what i am doing here  :y
still have slight flctuation on mine....got to say - Bit like Broocies at the lakes everything was pretty much spot on and clean / clear..
So i wasnt surprised when on restart it was exactly the same TheBoy you heard this MV6 at laes so you will know what i am talking about at idle....the revs fluctuate by the width of the 500rpm dash on rev counter....must be 50 revs or so of a fluctuation....
Ive checked, rechecked, torqued everything, checked all cables etc and nothing is amiss.
Also no fuel consumption issues, no acceleration issues at any point and no starting issues.....just that 10% idle fluctuation...
thoughts?
« Last Edit: 22 July 2007, 14:55:37 by Markiec »
Markie
Re: Whats causing my rough idle..
« Reply #1 on: 22 July 2007, 14:54:16 »
...also meant to say whilst iding i have no difference in idle speed when air con etc etc is on - im sure my revs at idle used to increase a few hundred.... :-/
Dazzler
  • Haverhill, Suffolk
« Reply #2 on: 22 July 2007, 16:52:48 »
Have you tried replacing the IACV or just cleaning it???
Markie
« Reply #3 on: 22 July 2007, 16:58:16 »
swapped it out for a spare that was "known good"
« Reply #4 on: 22 July 2007, 19:21:16 »
Knowing your skills, nothing to add really.
does seem to be airleak....  ....have you blanked egr? removed all intake stuff (red gasket knackered?) etc?
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
« Reply #5 on: 22 July 2007, 21:26:21 »
My revs do go up with air con and fuel use increases from 0.2 to 0.3 mph at idle.  Mine ran odd for a while and then sorted itself out - I blamed the throttle butterfly.  Does sound like an air leak somewhere. :(
« Reply #6 on: 22 July 2007, 22:13:37 »
Hi,
in my idle problem throttle potentiometer solved the problem..May be this will help..
Also I remember somewhere else I read old lambda sensors cam make small fluctuations..
PS: Blocked EGR also effect the idle from time to time..
« Last Edit: 22 July 2007, 22:15:03 by cem_devecioglu »
Markie
« Reply #7 on: 23 July 2007, 15:44:07 »
not blanked egr...but will be doing so :y
Mike Collins
  • North of Bristol
« Reply #8 on: 23 July 2007, 16:54:58 »
Blanking the EGR certainly smoothed the idle on my wife's 2.5.
Does it start without opening the throttle? cam sensor fixed that one.
Markie
« Reply #9 on: 23 July 2007, 20:06:13 »
yep spot on in every other way Mike  :y
