Author Topic: squealing brakes  (Read 4776 times)
Nickffc
  • Terrington St Clement, Norfolk
squealing brakes
« on: 23 July 2007, 14:20:50 »
Did have a look if this had been covered before but could'nt find anything....
So.....my bloody mega is screaming it's nuts off and it's driving me mental...!
does'nt start screeching until it gets a bit warm....maybe five or so miles of driving, hard braking no squeal, light braking when pulling up at the lights really loud....also if i drive very slowly like in traffic and i just touch the brakes it will also squeal then.
i have recently repalced all pads (good quailty)front and back but not been in to the drums yet.
please help......i'm slowly loosing my hearing....!
Nick
MV6 Estate V reg 3.0
DRIVE IT LIKE YOU STOLE IT......!!!!
3.0 MV6 Estate
1.9dti Astravan sportive
luv_my_mv6
  • Northwood (London)
  • Just one thing after another
Re: squealing brakes
« Reply #1 on: 23 July 2007, 14:23:17 »
Not changed any omega brakes yet, but when you did yours, did you replace the anti squeal shims correctly?
« Reply #2 on: 23 July 2007, 14:37:44 »
On fronts, pads have the springs built it - were these seated correctly? Rears have a spring plate. Any antisqueal compound/coppaslip on pad backing plates?
« Reply #3 on: 23 July 2007, 14:56:21 »
Simple....you need to file a leading and trailng chamfer to the brake pad friction material.....Vx front pads have this as standard, the rears do not (cant comment on after market stuff).
Also, ensure that the the pad backings are greased and the edges that make contact with the caliper are also greased.
Nickffc
« Reply #4 on: 24 July 2007, 14:06:16 »
yep all seated in all the right places,  copper slip applied.......i'll try the filing method next......
thanks chaps
nick
3.0 MV6 Estate
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« Reply #5 on: 24 July 2007, 17:06:52 »
mine had new-ish delphi pads on the front, which had two problems - one being that they'd click when first braking - which I guess was the pads moving in the caliper - the other being squealing. I tried reseating, applying copper grease to the back of the pads and the guides on the caliper, no joy.
Replaced the discs and pads for genuine Vx items - both problems went away ...
amba
  • Medway towns
    • German V6
« Reply #6 on: 24 July 2007, 22:13:41 »
Had similar noises when had mine changed last..complained to my mechanic and he told me he had used some strange make from his supplier...said he would replace under warranty with mintex pads and front discs..no noises since so expect it is after market quality problems...megas seem to work better with genuine parts..bit more coslty but less issues in long run.
« Reply #7 on: 24 July 2007, 22:16:57 »
Not if you get a Tradeclub card :y
« Reply #8 on: 24 July 2007, 22:18:39 »
I have never understood why the pads arnt supplied with leading and trailing edge chamfers (the Vx fronts have them) as its the key cause of squeal......this works also on push bike brakes....
Taxi_Driver
« Reply #9 on: 24 July 2007, 23:15:55 »
Just read this with interest......coz ive got a similar prob.....tho not as bad....
Admins feel free to start this as another thread....but i thought another brake problem thread was one too many  ;D
When my front brakes are hot slight squeal when brakes lightly applied....develops into a grind when pressed hard.....slow moving tho....less than 20mph.
They've been slightly sqealing for a couple of months now.....last couple of weeks grind noise has started.
ie as you get to about 20mph slight squeel starts and then at the last moment before you stop i can hear a slight grind noise
New vx pads and disk about 10k ago.
Took the pads of today (plenty of wear left on em) and sprayed generous amounts of brake cleaner on the disks and pads....put em back together and its made bog all difference  :(
Gave the outside of the pads a good dose of copper grease first too
Should i try new pads next.....or is it worth getting a power sander on the pads to ruff the surface up a bit....to see if this does the trick??  :-/
« Last Edit: 24 July 2007, 23:17:26 by Taxi_Driver »
Nickffc
« Reply #10 on: 24 July 2007, 23:17:15 »
and how would one obtain said card.....!!!!
3.0 MV6 Estate
Taxi_Driver
« Reply #11 on: 24 July 2007, 23:21:02 »
Ask vx dealer for one......tell porkies on it fill it in honestly and one should appear  :y
« Last Edit: 24 July 2007, 23:21:34 by Taxi_Driver »
« Reply #12 on: 25 July 2007, 08:21:44 »
You can try blagging one from dealer, not easy. Or join autobahnstormers.co.uk for £20 per year, and get one that way ;)
« Reply #13 on: 25 July 2007, 09:32:56 »
TD, I suspect the leading and trailing edge on your pads has worn away.....re-make it and they will be fine again.
Taxi_Driver
« Reply #14 on: 25 July 2007, 09:44:05 »
Cheers Mark....I'll get a file out at the weekend and give it a try  :y
