Author Topic: Couple of problems  (Read 2380 times)
NML
Couple of problems
« on: 25 July 2007, 16:31:36 »
I've got a couple of problems with my omega
Firstly, Its started cutting out when I pull up to a junction or at traffic lights etc, but it starts straight away after
Second, The power steering is really heavy when I dont give the car some revs, is this normal or is something wrong
ians
  • Reading
Re: Couple of problems
« Reply #1 on: 25 July 2007, 16:42:37 »
Read this on your idling problem and also the guide on cleaning throttle body/breathers/idle control valve on a 2.2 (2.0 is very similar).  This is a universal problem on the 2L engine, but easily solved.  Just a bit of work.
http://www.omegaowners.com/forum/YaBB.pl?num=1184578248
Is the power steering fluid up to the mark?
NML
« Reply #2 on: 25 July 2007, 17:40:45 »
the fluid is up to the mark
Craig_R
  • Watford
« Reply #3 on: 25 July 2007, 18:12:40 »
The Stalling problem is an easy fix if its just breathers and ICV need cleaning could also be a air leak check around for hissing sounds
But it sounds like your power steering pump is on its way out you may need another one
Mod's
[To be Fitted]Reverse Sensors
« Reply #4 on: 25 July 2007, 18:49:58 »
As above, clean the ICV, thats the good news :)
Bad news is the PAS pump sounds like it is at the end of its life :(
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #5 on: 25 July 2007, 21:36:54 »
Some models have a relay in the drivers footwell kick panal,as steering is electrically assisted.the relay has been known to intermit fail causing heavy feel when parking.
 Check to see if your model is this type,and change the relay first.[much cheaper than a new pas pump]
GARY :y
Jaguar XJ6
« Reply #6 on: 25 July 2007, 21:41:37 »
GARY :y
No Omega has electricallly powered steering
ffcgary1
  • Mitcham,Surrey.
« Reply #7 on: 25 July 2007, 21:45:41 »
Mine has a relay in the kick panal,to assist the pump.mine failed about a year ago and my pal a tec a vx changed the relay and problem gone. :)
Jaguar XJ6
« Reply #8 on: 25 July 2007, 21:50:30 »
Ah, no, thats to do with the speed sensitive PAS (which is still hydraulic), not fitted to OP's 2.0l car....
Grumpy
  • Manchester
« Reply #9 on: 25 July 2007, 21:51:09 »
V6's have Servotronic speed sensitive system, 4 pots don't.
'NML' has a 4 pot according to his profile.
Grumpy
  • Manchester
« Reply #10 on: 25 July 2007, 21:52:12 »
Beat me by a minute, 'The Boy'.  :)
ffcgary1
  • Mitcham,Surrey.
« Reply #11 on: 25 July 2007, 21:54:39 »
Thats the name of it  'servotronic' i knew i was'nt talking bull,but must admit did not look at his model. ::)
Jaguar XJ6
