Author Topic: Air Con  (Read 1648 times)
miggy
Air Con
« on: 27 July 2007, 17:20:15 »
Please could someone advise on how to add the air con treatment, I have been told it can be done without taking to Vx.
At the moment it smells like Mrs miggys socks.  ;D ;D ;D Hope she dont read that bit.
x25xe
  • Hayes, Middlesex
  • Avater removed due to size
Re: Air Con
« Reply #1 on: 27 July 2007, 18:35:51 »
Generally, you set the air con on recirculation and at full speed, make sure all windows sunroof etc are closed and open the can in the passenger footwell.  You have to leave the A/C running for some half hour.
It then kills the bacteria that are growing on the evaporator which causes the smell.
Any kit you get should have full instructions on it.
Hope this helps and good luck.
Taxi_Driver
Re: Air Con
« Reply #2 on: 27 July 2007, 20:35:39 »
First I would check the pollen filter isnt sitting in a manky puddle of water.....if the drain isnt blocked its probably worth changing the pollen filter anyway if you carnt remember when you changed it last  :y
As said the instructions will tell you how to use the deodoriser.......i have seen it, aerosol can version, of being squirted down the air inlet, with pollen filter removed and all the vents open.
miggy
Re: Air Con
« Reply #3 on: 27 July 2007, 22:40:42 »
Thanks for that chaps, I will give it a go.
 :y :y :y
