Author Topic: engine running lumpy  (Read 2043 times)
prr
  • paignton devon
  • dont be scared to take it apart
« on: 27 July 2007, 21:56:35 »
hi to all well my my meega has just started to run lumpy when pulling off when its hot or cold will run fine just once shes on the way with no problems and also at low speed 30mph ish she will begin to stutter every now and then
i have cleaned the idle valve and breather pipes about 6 weeks ago its just started to do this to me now but it seems to be getting worse any ideas out there
cheers
Dazzler
  • Haverhill, Suffolk
Re: engine running lumpy
« Reply #1 on: 27 July 2007, 21:58:22 »
Check for oil in the spark plug wells
« Reply #2 on: 27 July 2007, 21:58:35 »
Lets start with the easy stuff.
1) Any oil in the plug wells?
2) Any ECU light on?
3) Any damaged breather, inlet, vac pipes etc?
prr
  • paignton devon
« Reply #3 on: 27 July 2007, 22:05:46 »
no oil in the plug wells all is dry
no ecu lights
no breather/vac pipes off / damaged
this only happens now and then
« Reply #4 on: 27 July 2007, 22:11:35 »
Ok....
Next thoughts are:
a) EGR sticking open occasionally
b) Plug leads
c) DIS pack
prr
  • paignton devon
« Reply #5 on: 27 July 2007, 22:17:36 »
will check plug leads can the dis pack be tested also where is the egr thanx so far for the help
holey head
  • leeds uk
  • i'm a new dad
« Reply #6 on: 27 July 2007, 22:39:23 »
egr valve is at the rear of the enginge <as you look at it from bonnet> on passenger side.
ouch my head hurts! i'll try and remember to wear my helmet next time i'm out on the quad!
nixoro
  • Hitchin, Herts
« Reply #7 on: 28 July 2007, 15:09:54 »
Mine has started to do something similar.
Cold start or if its been parked on abit of a slope it rocks then I blip the accelerator a few times and it seems to clear itself.
My thoughts were the fuel filter possibly gunked up from letting the petrol run into the red before refilling.
Shall have a look at the plugs etc tomorrow just in case its one of these simple issues that have been already mentioned.
« Reply #8 on: 28 July 2007, 20:24:41 »
Mine also have similiar behaviour..Morning engine starts normal.Idle normal.But when you put in gear and push accelerator it hesitates a few seconds ..After become normal..
Before I changed nearly everything for normal idle (it become obsession > IAC valve, spark plugs, DIS,cables,throttle potentiometer, thermostat, Coolant TS...EGR Blocked-closed Finally idle become normal)  (What is left >  MAF, air temp sensor ,oxygen sensors, fuel pump..)
Tried also normal cleaning procedures for all breathers, even tried carbon clean..No effect..
Now the service tell its MAF..But no EML light..
I think the problem is related to either too much air or inadequate gas flow..
We measured air flow during normal idle (tech 2) (but the engine was hot) air flow was within normal range  (no leakage at that moment)
Now will measure fuel pump at start up.Only this is left
And pump was changed before (20 K miles passed)
« Last Edit: 28 July 2007, 20:33:55 by cem_devecioglu »
The Cambelt Kid
  • Derby
« Reply #9 on: 29 July 2007, 00:13:40 »
prr  - My 2L had this problem a while back.  I noticed the problem more when running on LPG and as it got worse i noticed it while on petrol.  I resolved this by replacing the HT leads, only 30notes from Halfrauds.  :y
[size=18]Project LP6 has landed![/size]
[size=12]DIY LPG now finally complete!! Whoo hoo.[/size]
