Author Topic: First day back at Uni went VERY well :)  (Read 2636 times)
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
« on: 24 September 2007, 16:37:26 »
 ;D ;D ;D
Humbugs...
Dazzler
  • Haverhill, Suffolk
Re: First day back at Uni went VERY well :)
« Reply #1 on: 24 September 2007, 16:47:06 »
 :o Yours??
PaulW
« Reply #2 on: 24 September 2007, 16:50:30 »
Yes  ;D
Love it  8-)
Humbugs...
Danny
  • Wigan, Greater Manchester
« Reply #3 on: 24 September 2007, 16:50:34 »
is that yours?? what uni course was that for?
I love how you're trying to tow a big orange van even though your rear wheels dont touch the floor
did the front wheel drive conversion cost much??
 ;D ;D ;D
PaulW
« Reply #4 on: 24 September 2007, 16:53:43 »
Yeah thats mine ;D ;D ;D I didn't actually do a FWD conversion, I just tied some reigns to the RAC bloke and made him pull it like a horse & cart - he was just taking a breather at that moment in time :) (and trying to escape  >:( )
Course is Computer Games Tech, repeating the 2nd year, so its a perfect way to start it  :y
« Last Edit: 24 September 2007, 16:54:20 by PaulW »
Humbugs...
Dazzler
« Reply #5 on: 24 September 2007, 16:53:51 »
 ;D ;D ;D
Very good ;D
« Reply #6 on: 24 September 2007, 18:19:22 »
I'm guessing that you didn't take my general advice the other day that all v6 owners should paperclip their cars, and hence you didn't know your cranksensor was going to fail?
PaulW
« Reply #7 on: 24 September 2007, 18:25:31 »
 :D Unless the crank sensor causes the engine to become a Sauna then no  ;D
« Last Edit: 24 September 2007, 18:25:42 by PaulW »
Humbugs...
« Reply #8 on: 24 September 2007, 18:29:07 »
What was the problem in the end mate? Do you ever get down my way?
MikeDundee
  • Costa Del Peckham
« Reply #9 on: 24 September 2007, 18:30:26 »
Looks like you had a good first day then ::)...............well done ;D
PaulW
« Reply #10 on: 24 September 2007, 18:35:24 »
Very rarely - I'm pretty much next door to Pete tho...
Not too sure on the problem yet... The RAC bloke suggested a few things...
Possible HBV giving in a bit when the coolant system is fully pressurised (its fine when cold/just warming up)
Pete said about the Oil Cooler sealing plate thing, may not of been sealed right or could of just sprung a wee leak.  Also said about possibility of dodgy plugs & leads for the poor running as he said the plug wells were full of oil when he did the rocker gaskets.
RAC guy also said the main cooling fan wasn't kicking in, and the only one kicking in was the aux one at about 100...  so the fans were kicking in well after boiling...
RAC guy also said that there might be a problem with the thermostat??  He let the car reach around 95deg with the cap off the coolant bottle to get rid of any airlocks, and said the water was still cold in it while the engine itself was warm & toasty.  The waterpump was working though as when the engine was hot, and the coolant res started to heat up, the water was pumping through ok.
Oil filler cap was a bit mayo-ee... BUT its the first 12 miles its done since Pete did the oil cooler & such, so its the first proper run its done.  So will more than likely just be condensation :)
Also worth a note, when I stopped at the garage to admire the sauna, the coolant level had dropped about 1cm from MAX on the bottle itself, so whatever the leak was it wasn't that bad at the time...
Humbugs...
PaulW
« Reply #11 on: 24 September 2007, 18:38:41 »
RAC guy also said he doubts its the HG as the coolant seem'd to behave itself, no weird noises, starts fine, and there didnt seem to be too much excessive pressure in the cooling system...  But after the car was running while he was having a good look over, engine stopped, he took the cap off the header tank and it was like it wanted to have a little wee wee on the guy  ;D
Humbugs...
Craig_R
  • Watford
« Reply #12 on: 24 September 2007, 18:44:29 »
can i ask i daft question why is he towing your car backwards ?
Just wondering as when a AA guy towed mine behind his lowloader as he already had a car on the back, down the M1 for 150 miles he had the front wheels up not he backs  :-/ :-/
Mod's
[To be Fitted]Reverse Sensors
PaulW
« Reply #13 on: 24 September 2007, 18:45:47 »
It's an automatic.  You 'can' kinda tow it from the front, but to avoid any damage to the autobox they recommend putting it on an a-lift and towing it from the rear :)
Humbugs...
« Reply #14 on: 24 September 2007, 18:47:17 »
Without having insider knowledge I'd say the Omega is an automatic!  :y  :y
Page created in 0.042 seconds with 20 queries.
