Author Topic: exhaust manifold help please  (Read 1839 times)
holey head
  • leeds uk
  • i'm a new dad
« on: 28 July 2007, 12:32:59 »
hi all
i've just bought exhaust manifold for miggy but then looked through manual and at car and it looks like a BIG job, is it a big job or is it quite easy? if anyone near leeds who could do it that would be great, just tell me how much!!!
cheers steve
« Last Edit: 28 July 2007, 12:53:36 by sparks3ks »
ouch my head hurts! i'll try and remember to wear my helmet next time i'm out on the quad!
Re: exhaust manifold
« Reply #1 on: 28 July 2007, 12:35:11 »
hi all
cheers steve
I think the 2.0l ones is easier than v6 ones ;)
holey head
  • leeds uk
  • i'm a new dad
« Reply #2 on: 28 July 2007, 12:36:26 »
looks really awkward to get at all of it!
nixoro
  • Hitchin, Herts
Re: exhaust manifold help please
« Reply #3 on: 28 July 2007, 15:31:21 »
Having done mine twice and done my dads now, it can be a real pain but the rewards are worth it.
How I did mine was unbolt the cat from the underneath at the down pipe end 4x 13mm bolts from memory.
Remove the rear breather pipe oil separator if you have one or just remove the rubber breather pipe, usually held on with spring clips.
Working from the top remove the bracket which hold the heat shield in place.
Remove the heatshield 3x bolts or screws
Remove the rubber breather pipe which comes from the metal rail.
Remove the metal rail held by 2 bolts hex type, allen key type from memory. Removing this rail can be fiddly as it goes around the rear breather pipe.
Then its a case of removing the studs/nuts for the manifold itself. Once the studs/nuts are off/out the manifold should just pull off the block.
Always use a genuine gasket and new studs/nuts from Vx as copies dont last as I found out.
The first time I did this I did it in a day, I can now do it in even less time with all the practice so worth having a go yourself.
I also recommend using some penetrating fluid on the downpipe to manifold bolts the night before as the y can break which is one downside. also if you can do the same with the manifold studs/nuts as this makes life easier when removing and hopefully helps to prevent studs snapping.
Good luck if you have ago yourself. :y
« Last Edit: 28 July 2007, 15:38:20 by nixoro »
« Reply #4 on: 29 July 2007, 11:03:11 »
I think you should do a How2 ;)
nixoro
  • Hitchin, Herts
« Reply #5 on: 30 July 2007, 16:39:17 »
I shall give it ago  ;D :y
