Author Topic: Strange Running Temp  (Read 2645 times)
jimmygixxer
  • Kent
« on: 30 July 2007, 16:49:49 »
Hi all
I have a bit of a weird one which i hope someone cn shine some light on, i have a 2.0ltr estate which when running has quite eratic temperature it fluctuates all the time regardless of going uphill or down a motorway, it will get up to 95 quite quickly from cold and from then will range between 95 and 100 but never overheats.
when sitting it will often get to 100 but then cool down due to the fans.
also i may be being dumb but when i have the ac on it runs hotter than normal ie when normally at 95 it will be running at 97.
i have had the coolant sniffed about 6 weeks ago all ok so hopefully not the dreaded HG!!!
cheers all
ians
  • Reading
Re: Strange Running Temp
« Reply #1 on: 30 July 2007, 17:01:30 »
Hi and welcome!
My 2L also fluctuated quite a lot, and certainly got hotter in slow traffic.   I think its normal to run a little hotter when the ac is on.
It may be your stat is sticking a bit but to be honest I wouldn't worry about it from what you describe.
Cheers
Ian
cdx estate omega
  • sheldon, birmingham
« Reply #2 on: 30 July 2007, 18:03:35 »
My 98 2.5 V6 also does the same, always runs at or just below 95, but in hotter weather will fluctuate a lot between 95 and 100, never had it over heat so far.
Danny
  • Wigan, Greater Manchester
« Reply #3 on: 30 July 2007, 18:03:53 »
My 2.0 doesnt have this problem, It seems to run at around 90 once it's been running for a few minutes, if i keep a constant speed for a short while on an open road and keep the revs at minimum, it can cool to less than 85, never really goes over 92 max that i've noticed
jimmygixxer
  • Kent
« Reply #4 on: 30 July 2007, 18:37:34 »
hmmmm i think im slightly paranoid as my 53 vectra sits about 85 all the time, rarly has the fans running,
i wonder if a coolant change is in order as it does look quite dirty and possibly some new coolant will lubricate the thermostat.
any suggestions.
its a 99 omega by the way if that makes any difference???
old cruiser
  • Slough
« Reply #5 on: 30 July 2007, 18:57:48 »
I would suggest dumping the coolant, good flush through and changing thermostat at the same time.
Cheers Pete
jimmygixxer
  • Kent
« Reply #6 on: 30 July 2007, 19:31:50 »
is a thermostat change an easy job?? i know my way around an engine sort of but im by no means a mechanic!!! i have read the maintainance guide for a coolant flush which is very helpful but not sure about the thermostat!!!
« Reply #7 on: 30 July 2007, 19:56:51 »
Thats too hot tbh, shouldn't really rise above mid point on gauge.  Flush coolant, if possible with some proper flush...
jimmygixxer
  • Kent
« Reply #8 on: 30 July 2007, 20:04:34 »
proper flush wot do you recommend???
« Reply #9 on: 30 July 2007, 20:05:21 »
Forte Cooling System Flush.
