Author Topic: coolant flush  (Read 1679 times)
megaomega123
coolant flush
« on: 30 July 2007, 17:52:44 »
I am just doing coolant flush and change. The water is really rusty looking. I have flushed 3 times and still rusty. If I leave the bleed tap open and refill it runs clear. So obviously the rust is through the system.
Shall I just keep flushing until it runs clear? Also there is a metallic tinkle somewhere mid enigine. Is this likely to be water pump or does cambelt tensioner make this type of noise?
I hasten to add that both are being done this week :y
Dave-C
  • Staffordshire
  • The Old Girl
Re: coolant flush
« Reply #1 on: 30 July 2007, 17:59:18 »
Possibly worth taking the radiator pipes off, flush and reverse flush seperate to the engine... if it's gonna clog anywhere... this and the heater matrix are the place..
DC
Re: coolant flush
« Reply #2 on: 30 July 2007, 20:12:35 »
you can only get half coolant out on v6, unless you remove pump.  do the full flush when you're doing that...
