Author Topic: lack of power and bad idling!  (Read 1470 times)
ben1975
  • West London
« on: 30 July 2007, 15:16:23 »
I am new to the omega owners forum and i am currently on my 2nd 3.0 elite.
This one i have not had long, and i have had quite a few issues with it.
Recently i had an LPG conversion done, and when i picked it up it was idling rough in LPG but fine in petrol.
The chap from the LPG centre said there was oil on a couple of the plugs and that could cause a bad idle as LPG is more sensitive than petrol.  On the way home on the motorway, had no power issues and the LPG was smooth.
About 2 weeks later the car was running very rough and i took it to a garage and they said there was oil on the spark plugs and in the chamber, which they said was the rocker cover gasket.  I had all this repaired and it was running fine, then yesterday it started running very rough and there was a lack of power. Also after i had the car repaired it was still running rough on LPG, even with new plugs.
Could it be the HT leads gone?  As i have read the oil can burn them out.
Does anyone have any further ideas on what could be causing this?
Last question, is there anyone out there that can reccomend a good LPG garage in west london or essex, as i need to get the lumpy running looked at.
If anyone can help its much much appreciated.
Ben
razzo
  • Crapital
    • 97 3.0 Elite
Re: lack of power and bad idling!
« Reply #1 on: 30 July 2007, 16:13:17 »
yes Ben, oil in the plug wells can slowly cook HT leads to destruction as for LPG someone else can advise you
Tafty
  • Liverpool
  • This week I am no longer the owner of a miggy!! :(
« Reply #2 on: 30 July 2007, 16:22:58 »
What spark plugs are installed - the 4 way electrode ones I believe arn't too good for LPG and the 2 electrode give better performance.
The Cambelt Kid
  • Derby
« Reply #3 on: 30 July 2007, 23:15:08 »
HT leads cured all my LPG running woes on my 2Ltr!  Problem i had occured only on LPG at first but then as the leads began to break down even more over time i noticed it on petrol too.  This all occured after i replaced my leaking cam seals, so i guess the oil may have cooked the leads, that and the fact they were 150k miles old!!  New leads gave better peformance,Mpg and a smile on my face.  :)
I'm not too sure where to get leads for the V6 as i had a 4 pot at the time and Halfrauds was advised as the best place for them!  I think a guy called MTEK on here does good leads for the V6??  :y MTEK are you there??
Hope this helps.
Cheers
Marc
[size=18]Project LP6 has landed![/size]
[size=12]DIY LPG now finally complete!! Whoo hoo.[/size]
