Author Topic: Drivers side centre box  (Read 1422 times)
megaomega123
« on: 31 July 2007, 15:39:07 »
What problem could cause a new drivers side centre box to blow within a week. This is now the 2nd box and it is noisy as hell :question
Grumpy
  • Manchester
Re: Drivers side centre box
« Reply #1 on: 31 July 2007, 15:55:24 »
You just say that it's noisy.
Where has it blown? Have you looked at it?
Is it from a joint?
Has something punctured the box?
Has it been fitted incorrectly, under stress, so that a joint or
weld has broken?
megaomega123
« Reply #2 on: 31 July 2007, 15:57:45 »
It's just ticking and rattling inside. Ticking on idle and rattle @ 2000rpm upwards. No noticable holes or defects on the exterior.
Grumpy
  • Manchester
« Reply #3 on: 31 July 2007, 16:24:46 »
Not had one of these apart, so don't know if it's a 'Baffle' or
'Perforated' type.
If it's the 'Baffle' type then it could be a manufacturing fault that's
given you a loose or broken baffle plate.
Sounds can carry along an exhaust system. Seeing as it's been
newly fitted, are you positive that it's not been fitted so that it's
lightly vibrating against the underside of the body anywhere?
With the engine stopped, if you tap upwards with your hand (wrapped
in a cloth or gloves), can you hear anything loose inside the box?
