Author Topic: urgent advice please  (Read 1798 times)
raximax
  • dundee
« on: 02 August 2007, 10:38:37 »
hi guys me again i did my hbv last night but still overheating and air block (no hot air) away to flush again .if this dosent work i get a thermoststat im saposed to be pulling the caravan tomorow ive told the wife if the car is still overheating i aint pulling anything vauxhall dont have any in stock could i get another one from some place :question and are they easy to fit im a novice the symtoms are
warmes up as normal
then gets hot when driving around 30
ok on motorway well better
sometimes drops slightley when you blip the throtle
a little discoloration in the header tank and flecks of white stuff
any advice welcome sooner the better divorce is costley :(
mmeeggaa
Re: urgent advice please
« Reply #1 on: 02 August 2007, 11:29:15 »
I suspect a blockage in the rad......also check the fuses in the ecu bix in the engine bay. Some of these operate the fans and in particular the two fans at the front of the car.
raximax
  • dundee
« Reply #2 on: 02 August 2007, 12:07:10 »
the two fans are coming on but a bit on the high side for me. how do you check the rad? ive drained and refilled the system let it heat up while squeesing the hoses but no joy could i have broke something fitting the bbv? the hoses are in the right places.i can see the water returning from the rad but not sure if there is is the right amount think ill go to halfords and get some more rad cleaner in saying that the water dond seem to bad.....thanks for the reply
mmeeggaa
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #3 on: 02 August 2007, 22:00:11 »
I suspect a blockage in the rad too..  try flushing and reverse flushing the rad alone with a hose pipe...  I had the same problem after flushing.. it obviously losened the sh1te and bunged up the chanels... I doubt it's the stat...
Best of luck...  take the towing steady..
DC
