Author Topic: Temp Gauge off & on  (Read 2101 times)
Boiler Man
  • Sale, Manchester
Temp Gauge off & on
« on: 02 August 2007, 16:10:47 »
Hi Guys
Hope someome can advise me.
My temperature gauge is working fine one day then not at all next day. It tends to be when there is a warm day and I check the gauge for any overheating and its showing zero. Then the following day okay.
The car runs fine and I have cleaned the spade connection on what I think is the temperature sensor. But it keeps happening. :(
Any ideas? is it the sensor or the gauge? :y
Omega 2.0 DTI GLS Estate 99 Gold & Omega 2.2 DTI CDX Estate 03 Silver. Just need a Bronze one now for the full set.
Dave-C
  • Staffordshire
  • The Old Girl
Re: Temp Gauge off & on
« Reply #1 on: 02 August 2007, 19:01:52 »
Not aware of any inherent issues with this fault...   sounds to me like a faulty temp sender, going HR in hot conditions...  If you remove the plug and bridge the connections, guage should read high.. this will prove the guage, OK... if not flty sender....
DC
Boiler Man
  • Sale, Manchester
« Reply #2 on: 02 August 2007, 20:06:02 »
 :y When you say bridge the connections. What I think is the sensor only has one spade connection with a single wire to it.
This is on top of the thermostat housing. :-/
Or am I looking at the wrong thing?
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #3 on: 02 August 2007, 20:36:29 »
Sorry,  take it to a negative i.e engine block...  some may say via a resistor on some vehicles....  DC
Boiler Man
  • Sale, Manchester
« Reply #4 on: 02 August 2007, 22:23:51 »
 :y Cheers
I'll try that tomorrow.
Dazzler
  • Haverhill, Suffolk
« Reply #5 on: 02 August 2007, 22:52:45 »
I had this problem on my Omega once, in the end the gauge stopped all together. After a lot of fault finding i traced the fault back to the bash board itself. The fault was actually where the dash connects to the loom, it is a push fit. But before you start stripping things down just push the clocks in to make sure the connection is good. This was all that was needed on mine in the end, when i pushed the clocks they moved back about 4 mm or so and bingo the temp gauge has worked ever since ;)
« Reply #6 on: 02 August 2007, 22:54:16 »
I've had it before, was dash not fully seated...
jonathanh
  • coventry
« Reply #7 on: 03 August 2007, 07:42:52 »
I've a similar problem.  temp guage sometimes sticks.  Easily fixed by a gentle tap on the dash, seems to work ok after that
Boiler Man
  • Sale, Manchester
« Reply #8 on: 03 August 2007, 18:21:25 »
Cheers Guys  :y
Thanks for all your suggestions.
The one that worked-----------------The tap on the dials and the gauge started working,
Easy when you know how ;D
Strange thing my digi display brightend up too. :o
Must be a bit loose behind there, I'll take a look over weekend. I was nearly buying a sensor
Thanks Again :y [smiley=beer.gif]
Dazzler
« Reply #9 on: 03 August 2007, 20:25:23 »
« Reply #10 on: 03 August 2007, 22:49:27 »
Cheers Guys  :y
Hand on tacho, and push to reseat connector ;)
