Author Topic: quick vac pipe question  (Read 1843 times)
megaomega123
« on: 07 August 2007, 17:56:07 »
What should be attached to the arrowed vac pipe. It is the 1st one along the pipe and has a 2nd 1 inch further along. Can't seem to find a disconnected hose anywhere?
Any ideas?
Robin Hood
  • Nottingham
Re: quick vac pipe question
« Reply #1 on: 07 August 2007, 18:34:03 »
Air injection - just behind rad, top right.  Well that's where mine goes so I hope it's right.   :D
Robin Hood
  • Nottingham
« Reply #2 on: 07 August 2007, 18:36:20 »
Take a look at this maintenance guide...
http://www.omegaowners.com/forum/YaBB.pl?num=1152565204
megaomega123
« Reply #3 on: 07 August 2007, 18:46:09 »
By that map it looks like the one going to the Rear Vac Reservoir (mounted by the pollen filter).
Haven't done any work in the area and can't find a pipe to put on it.  :-?
Robin Hood
  • Nottingham
« Reply #4 on: 07 August 2007, 18:50:11 »
On mine the two connections have been swopped over, first the single and then the T piece which is why I added the link.
megaomega123
« Reply #5 on: 07 August 2007, 18:56:11 »
Mine are swapped to m8.  Found it and reconnected.  :-[  cheers  :y
