Author Topic: heavy steering  (Read 3624 times)
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
heavy steering
« on: 09 August 2007, 06:43:32 »
Hello I think I have another problem I have noticed that my steering seems to have become slightly heavy while driving its not excessive but just heavier than usual, the tyres look ok pressure wise and the fluid looks to be at the correct level. Any suggestions please  :)
Re: heavy steering
« Reply #1 on: 09 August 2007, 09:12:10 »
Is it worse at low revs?
LFF64
  • HADDENHAM BUCKS
Re: heavy steering
« Reply #2 on: 09 August 2007, 12:19:43 »
Hi, no not really  :-/ I may even be just imagining it but it does seem heavier than usual
Craig_R
  • Watford
Re: heavy steering
« Reply #3 on: 09 August 2007, 12:27:01 »
first port of call would be to check the tire pressure even if the tire looks ok i would still get a PSI meter to check it or go to the garage and use the air pump meter to check.
If they are fine then I think your power steering Pump is on its way out or as you say you could just be alittle picky like i am with everything on your meega  :P
Mod's
[To be Fitted]Reverse Sensors
Danny
  • Wigan, Greater Manchester
Re: heavy steering
« Reply #4 on: 09 August 2007, 13:20:30 »
low on fluid?
Timbuk
  • Telford
  • owned a Datsun 120y once!
Re: heavy steering
« Reply #5 on: 09 August 2007, 13:29:04 »
Fuse ?
LFF64
  • HADDENHAM BUCKS
Re: heavy steering
« Reply #6 on: 09 August 2007, 16:28:28 »
Well spotted there Timbuk  :) I was driving home and noticed I had lost the center section of the radio display and on checking also the cigarrette lighter was not working so I check the fuses and came across fuse 14 which is a picture of a heated seat 30A I this had blown  >:( I replaced the fuse and everything is now working  :) I thought it was going to be something really expensive  :'( .Thinking back the problem only occurded after I plugged a charger in to the lighter socket the other morning for someone  >:( I now have a feeling that the wiring is the wrong way around in the socket after having the center out to put the stereo in last week >:(
Anyway thanks for all the replies I hope in a way it may help someone out in the future  :y no way would I have thought to check a fuse for this problem I was thinking the pump had packed up. By the way does that mean the pump is electrical then and not belt driven?
Re: heavy steering
« Reply #7 on: 09 August 2007, 21:22:50 »
I suspect it was more than 'bit heavier than normal' ;D
LFF64
  • HADDENHAM BUCKS
Re: heavy steering
« Reply #8 on: 09 August 2007, 21:29:51 »
Your right there now its working again its a hell of a lot different, not too noticeable as only been to work and back but would have been a nightmare on a run  :) Is it a belt driven pump or elecrtic driven I assume its electric
Re: heavy steering
« Reply #9 on: 09 August 2007, 21:31:46 »
Driven from aux belt, but 6 cylinder Omegas have speed sensitive assistance, which electrically adjusts the amount of hydraulic assistance it gets, if that makes sense...
LFF64
  • HADDENHAM BUCKS
Re: heavy steering
« Reply #10 on: 09 August 2007, 21:37:18 »
 :) oh yes that makes sense  ;) I had looked under the bonnet and it looks belt driven thats why I thought the pump had packed up, it never occured to me to check for a fuse  ;D I wonder how many people have been caught out by the blown fuse. Thanks for the help  :y
Re: heavy steering
« Reply #11 on: 09 August 2007, 21:40:20 »
A few have fallen for that one ;)
The other is when the ABS unit packs up (not uncommon on post 98), same problem....
Dazzler
  • Haverhill, Suffolk
Re: heavy steering
« Reply #12 on: 09 August 2007, 21:43:01 »
That will be mine then :( On its way to Re-man in the morning ;)
Re: heavy steering
« Reply #13 on: 09 August 2007, 21:50:05 »
Only your 2.0l won't have speed sensitive steering...
Dazzler
Re: heavy steering
« Reply #14 on: 09 August 2007, 22:06:41 »
Not the 2.0 the sick 2.5 Elite at the bottom of my page ;)
